Back from the dealership...tell me if this is right.
Yea, as you open the throttle, the percentage of throttle angle should change on the scan tool. (by the way, you don't sound like an idiot...you're just in the learning phase, and the fact that you were able to get some diag time on a scan tool for free proves you're not an idiot!)
Good job getting the diagnostic for free
that should be that hard to figure out.theres 3 wires plugged into it. one wire should have 5 volts going to it. one should be ground and one is a refrence wire to the pcm. one wire is probably open. shouldn't take more than 10 minutes to figure out which one it is. it could also have a spread terminal in the connector. maybe they have some lube tech working on it that dosent know what he's doing.
I just wanted to give everyone who posted on this thread an update. I checked all the wires today, and the wires are all ok. Putting in a new TPS Sensor did nothing when the truck was hooked up to the diag. computer. So my problem is my pcm right? Is this a programming problem with my current pcm, or it is physically damaged that's causing it not to read my tps? Do I need to make any mention of this problem when I get a new pcm tune? I'm planning on going with PCMforless here in a couple of months, and I really hope that takes care of the problem.
GregM
GregM
GregM
GregM
GregM
GregM
Check for water in the connector at the PCM. Had a Tahoe that wouldnt shift. After checking the TPS sensor and no change in the angle reading, traced the wires back to the PCM and found water in the connector .
atxlt
Jul 20, 2015 11:06 PM
