Auburn vs. Eaton
Old Mar 24, 2005 | 11:32 PM
Default Auburn vs. Eaton
I want to hear all the good and the bad about the two. The factory g80 is no good any more. Now I need to choose between the two. THX.
Old Mar 25, 2005 | 12:13 AM
Mr. Sandog's Avatar
I did oodles of research and got the Eaton. I found the Auburn gets recommend a lot because their required quantity for volume pricing for dealerships and shops is a lot lower than Eaton's. One shop owner told me he would have to sell $300,000/yr in Eaton products to get good pricing, whereas Auburn's quota was $60,000/yr. So the Auburns get recommended more. They're both probably good, but I found a skosh more negative feedback about Auburn units, so I got the Eaton. Plus the Eaton can be rebuilt, whereas the Auburn has to be sent in if there are issues, and the reman units cost almost as much as the new ones.
Good luck.
Old Mar 25, 2005 | 02:10 AM
Grey Silver's Avatar
11 Second Club
I've been running an Auburn unit for a couple of years with no problem. More $ usually means better parts but it's not always the case. Some people don't know how to keep oil in the rear end, change oil in the rear end , or put the right additives in when they do put oil in it. I'd bet that most of the negative feedback about the Auburn or the Eaton was caused by the owner. I'm about to open mine up for the 2nd time just to take a look and put some fresh oil in.
They're both good, I'd pick the one with the best price tag.
Old Mar 25, 2005 | 05:47 AM
samdogmx's Avatar
8 Second Club
eaton all the way
Old Mar 25, 2005 | 06:18 AM
bluecajun5.3's Avatar
11 Second Truck Club
i haven't had any experience with auburn but i can say that i like my eaton very much
Old Mar 25, 2005 | 06:48 AM
Same here, My Eaton has takin a beating.
Old Mar 25, 2005 | 08:33 AM
14 Second Truck Club
Eaton- rebuildable, tuneable, stronger.
Auburn- Sometimes quiter(usually equal), exchange program, no clutches.
I always reccomend the Eaton for performance.
Old Mar 25, 2005 | 10:51 AM
So does any one have any thing bad to say about ether one? Like the Eaton or Auburn I had exploded on me at 150mph when I was racing this Enzo, I lost control and killed both my truck and the Enzo! Ok, doesent have to be that bad but any problem storys?
Old Mar 25, 2005 | 11:02 AM
I broke the spider gears on an Auburn Pro at the track,then Auburn sent me a replacement at no charge.The Auburn was only a month old and I never have had other problems with the replacement.
Old Mar 25, 2005 | 05:57 PM
D Man's Avatar
So where is a good place and price to get the Eaton LSD and maybe a set of gears?
