-   GM Engine & Exhaust Performance (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/)
-   -   Atk lq4 hp93 (https://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/atk-lq4-hp93-527861/)
Joschdog Mar 26, 2014 12:44 PM
Atk lq4 hp93
How about this engine from ATK? It's the LQ4 HP93. Has anyone put that in a 99 nbs? Summit Racing thought I might need an intake from an 01 or newer and possibly modify the wiring harness.
Stage: 1
HP: 460
TORQUE: 470
Engine Type: Chevy LQ4/6.0L
Displacement (cu.in):366CI
Block: 6 Bolt Main
Bore / Stoke: 4.030 X 3.622
Crankshaft: OE 24 Tooth
Rods: Stock
Pistons: Hypereutectic
Rings: Moly
Camshaft Type: HYD. Roller
Camshaft Lift: CUSTOM
Camshaft Duration @.50:CUSTOM
Cylinder Head Type: OE Reman Aluminum
Chamber Size: 71cc
Valve Size: 2.00 IN X 1.55 EX
Intake Runner Volume: OE 210cc
Compression Ratio: 9.5:1
Rocker Arm Type: OE Steel
Rocker Arm Ratio: 1.7:1
Sheet Metal: Not Provided
Recommended Fuel: 91 Octane
Ignition Timing: 36 Degrees Total Advance
Max RPM: 6000
Warranty: 24/Unlimited
Dyno Proven: YES
Link:
GM LQ4 6.0L 2001-2007 460HP: High Performance Engines | ATK Custom Built Crate Engines
Thanks
GMC93 Mar 26, 2014 12:52 PM
Just bolt it in and go
Joschdog Mar 26, 2014 12:56 PM
Yeah? No mods required?
Chevy_King1500 Mar 26, 2014 01:15 PM
you will need to swap everything over.
tune will be a must and injectors
longtubes, intake, cool looking parts are up to you.
Joschdog Mar 26, 2014 01:56 PM
I have a Nelson tuned PCM right now. Wonder if they've tuned that engine b4...
zero2sixT Mar 27, 2014 06:42 PM
Look at thompson or hke. That enigne is stock with a very mild cam.
FYI, I got my afrs and lq9 longblock for a $100 less. They are used though.
Joschdog Mar 27, 2014 07:38 PM
Nice. Yeah, I was going to call Thompson. The power ratings are right where I wanted to be with this one though. what are you making with yours?
zero2sixT Mar 28, 2014 07:09 AM
I understand not everyone wants a max effort engine. And no doubt that engine would run well and be fun to drive. But they could've at least used arp hardware and 243s for the price.
My engine's numbers were disappointing. It was pulling vacuum on the intake after the heads went on. Only dyno'd 404/408. It still runs good. Kind of at a crossroads on what to do next with it though.
Flyin 1500 May 31, 2014 12:53 AM
How big would you go with the injectors?
gagliano7 Jun 3, 2014 10:32 AM
You could use the 8.1 truck injectors which plug right in and the tuning changes are easily made. Make sure your fuel pump is up to the task.
