Im really confused on the $3,600 price tag of a basically stock, remanufactured engine with an aftermarket cam. Guess you're paying for the warranty more than anything.
Originally Posted by zachm89
(Post 5221547)
Originally Posted by gagliano7
(Post 5221552)
The stock long block if you can find them cost the same or more. I would like to see this in a vehicle but 460 hp is a pretty nice bump over the stock 345 hp.
(Post 5221559)
Are you referring to trying to buy a new one from GM or...? You can most times get a complete turn key motor, intake to oil pan, all sensors, harness, PCM and hell even sometimes a trans (most likely a 2wd 80e) from places like LKQ or similar for less, and even those come with warranties (sometimes). Im not knocking these guys products, but for what you're getting, I just couldn't justify the price tag.
Last week I bought one from ATK and to my surprise it came in a couple days later with just about everything I needed to put it in, only missing a piece or 2 (new front crank seal). I got it put in last night and it fired right up had to tune on it for a while to get it to run right but finally got it half way there when I noticed the front crank seal leaking bad. (it was late I was tired) should have the seal replaced today, however I cannot get it all tuned up yet (still got stock exhaust with cats and all). hopefully next week I can get long tubes on get the cats out and put in the right injectors.
Even with the stock exhaust it has a good lope to it.
Originally Posted by slic25hd
(Post 5266412)
I would also like to know I am probably going this way in the spring.
Well i am not too impressed so far, i had stock exhaust and injectors the LS Performance guy tuned it for me and it pretty much runs the same as stock (rougher idle and 6k shift point) however i just deleted the cats and got the injectors in so hopefully after be reprograms it i will see a big difference. However i am doubtful.
My old engine had between 45-55 psi oil pressure at 300,000 miles and this new motor only has 25-40? I will let you guys know how it turns out after the injectors and new tune. Just a suggestion i paid 3,300 buying it through my company! Not bad savings compared to wbat they sell them to individuals for..
