Asp pullies, what belt??
Old May 6, 2003 | 01:42 AM
INDIGO 5.3's Avatar
Default Asp pullies, what belt??
What's up guys. I just ordered ASP pullies today . Truck performance had about 5 sets left at 180.00. Got them for 199.00 shipped. Now, since I got the crank and alt pulley I believe I will need belts, right? What part # are the belts for the pullies and can I get them from the dealer? I was told by a friend that I am going to need the main belt as well as an a/c belt, is this true? Can anyone please provide me with part #'s? Also, I did some research on the forum and saw that if you have both pullies it might cause a low voltage problem, I though it was the other way around? I thought if I got just the crank pulley I would have voltage problems. Please help. Thank you in advance.
Old May 6, 2003 | 02:58 AM
CashDudeHomie's Avatar
Default Re: Asp pullies, what belt??
All of the answers will vary based on which alternator pulley you got. Did you get the bigger one or smaller one? I have the bigger one and don't have any charging problems, even with LS1 fans. Check ASPracing.com for the belt numbers. Good luck installing it.
wickedRCSB
Oct 30, 2015 09:45 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
murderedSS
Sep 27, 2015 10:16 PM
97_ek
Sep 23, 2015 09:16 PM
hackrst
Sep 2, 2015 05:27 PM
