ASM Install
Old Jan 17, 2005 | 08:05 PM
Breeze's Avatar
11 Second Truck Club
Yea the passenger side is a bitch.
Old Jan 17, 2005 | 08:17 PM
Originally Posted by L-EATER
Somebody needs to fill you in on the busted knuckles, all the cursing thats gonna take place, and the 8 hours you are about to spend. The first time is an absolute SOB. Some people on here will agree and some say they went on with no probs. I guess it is just production tolerances, but some sets evidently fit better than others. I hope you get some good ones, otherwise have plenty of beer on hand....
You gotta give a little blood sometime
Your goimg to need a muffler shop anyway to weld 'em up cats or not. Some shops will do the install. Ask around, it's worth a couple of hundred $ easy.
Old Jan 17, 2005 | 08:34 PM
Silver-Dollar's Avatar
The shop I spoke with said they would install them for 225.00. I figured it would be worth it. Drop it off, go to work, and pick it up later makes it a little less expensive.
Old Jan 17, 2005 | 08:39 PM
sfj
yeah you might as well have the shop do it ... it is kinda high but worth the frustration
Old Jan 17, 2005 | 08:46 PM
I have Gibson Super Truck cat-backs with the polished rectangle tips. I give blood everytime I wash them.
Old Feb 2, 2005 | 01:52 PM
BLACKND's Avatar
Hey, hate to start this thread back up and all. But I had a similar situation with the ASM's. Sponser here pushing the Dynatechs, not hard, but was saying that there is a lot of modification to be done to fit the ASM's. I am planning on buying these from TByrne with his 10% off, and just wanting to know what all needed to be done. I too, am planning on having them installed, I was going to have the sponser install them.
Someone mentioned having to unplug the 02's, you don't have to remove them altogether do ya?
Old Feb 2, 2005 | 02:11 PM
FILE's Avatar
No, you just unplug them and plug them back on to the headers.
Old Feb 2, 2005 | 02:49 PM
BLACKND's Avatar
Well, thats what I thought, I was just trying to make sure. Are you using ASM's Tib?
Old Feb 2, 2005 | 04:24 PM
one03sierra's Avatar
Formerly one92rs
Talking
if you are fixing to install some. look down the firewall on the pass side. look at the heat shield. there is a stud sticking out down there. cut that end of it off first. then remove the coil packs from that side as well. after that it will go in a lot easier.
Old Feb 2, 2005 | 09:52 PM
CashDudeHomie's Avatar
Yes that little bitty stud is such a pain. For the driver's side I disconnected the steering shaft and installed it from the bottom. The passenger side has to go in from up top thru all the AC and heater hoses and it is a much bigger header and a much smaller space so be prepared to cuss a lot. Also mine burned a starter wire so you may need to loosen and turn that starter wire where it is not against the starter heat shield. You will know what I mean when you see it.
