ARP Main fasteners
Old Mar 25, 2007 | 06:36 PM
Default ARP Main fasteners
I am buying the ARP main stud kit from Summit ARP-234-5608 but I cannot seem to find the side studs/bolts. I used to have them bookmarked but Summit racing has them inexistent at the moment. Suggestions?
the part in question is "Main Studs, 4-Bolt, 10mm Side Studs Only, Chevy, 4.8/5.3/5.7/6.0L, Kit"
ARP-234-5608-SB
-David
Old Mar 25, 2007 | 07:03 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Ill get it for you when I get home.
Old Mar 25, 2007 | 07:48 PM
adam1803's Avatar
I was under the impression that the stock ones were used, thats what i did with mine.
Old Mar 25, 2007 | 08:15 PM
Flyer's Avatar
Same here .. THe side cannot be studded because if the way they are installed.
I suppose they sould be ... but it would be kinda pointless to stud the side.
Old Mar 25, 2007 | 09:14 PM
1slow01Z71's Avatar
They arent studs they are 10(or12 cant remember right now)mm 12 point black oxide coated bolts and it comes with a 10mm 12 point pickup tube bolt also.
Old Mar 26, 2007 | 12:04 AM
yea, that's why they don't come with the main stud ARP kit but I can't find the part number for it.
Old Mar 26, 2007 | 12:08 AM
Ferocity02's Avatar
No need for having ARP cross-bolts. They are only torqued to 18ft-lb and the stress they endure is minimal. Reuse the stock ones.
Old Mar 26, 2007 | 12:10 AM
Thanks for the info.
Old Mar 26, 2007 | 12:45 AM
1slow01Z71's Avatar
Thats true they arent tq'ed to much but thay arent seeing a tensile pull like the mains are they are seeing a torsional pull therefore a much harder bolt will have less torsional deflection then a stocker. While I dont feel they are really necessary for the 26ish bucks they cost, it makes me feel warm and fuzzy inside.
Old Mar 26, 2007 | 12:49 AM
I like to be warm and fuzzy, Cody, where do you think I could find the bolts? If i'm going to spend ~$500 in bolts for this build, the extra 25 for these won't be a problem
