ARP Head Studs
Old Feb 11, 2006 | 05:19 PM
Bradazz's Avatar
Default ARP Head Studs
I just installed my ARP Head Studs w/ the engine still in the truck and the installed the heads without any clearance problems. My only question is what torque specs should I use for the setup in my sig?
Old Feb 11, 2006 | 05:27 PM
Yelo's Avatar
If I remember right it's:
Torque to 75#'s, loosen, then retorque to 75#'s
Old Feb 11, 2006 | 05:29 PM
Bradazz's Avatar
Thanks alot, I'll go torque 'em down right now.
Old Feb 11, 2006 | 05:33 PM
Yelo's Avatar
No problem....
Old Feb 11, 2006 | 05:45 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Remember to put the chamfer on the washer facing up.
Old Feb 11, 2006 | 08:03 PM
Bradazz's Avatar
Thanks for the heads up on the washers. Does amybody know what are the torque specs for the 10 smaller nuts? Also are these torque specs that I was told good enough for Forced Induction (Radix)?
Old Feb 11, 2006 | 08:18 PM
99Silver6.0's Avatar
And use the moly lube.
Old Feb 11, 2006 | 08:30 PM
JimS's Avatar
Same instructions for the bolts as for the studs? (got ARP head bolts to go on with the new heads.)
Old Feb 11, 2006 | 09:39 PM
v8
17,16,15,14,13,12,11 Drvr
here this will help you alot.
http://www.ls1howto.com/
Old Feb 11, 2006 | 09:51 PM
1slow01Z71's Avatar
the small bolts/studs are 22ft-lbs dab of moly lube on the end and the chamfer up and ur set.
