Arp head stud questions unanswered
Old Oct 28, 2013 | 04:42 PM
timmay208's Avatar
i want to say they recommend different tq specs if using oil vs the moly lube
Old Oct 28, 2013 | 06:06 PM
thunder550's Avatar
High on diesel fumes
Sounds right to me as well.
DUK713's Avatar
I would call ARP direct and ask them. I would be very surprised if they don't have a tech line. The reason I say this is because I come from the diesel world where head studs are everything and ARP changed up the torque specs on the heads studs on my last diesel so you never know. Also I would clarify the whole moly lube vs oil but I imagine they will suggest their brand of lube which I suggest getting.
Old Oct 28, 2013 | 06:18 PM
IMI4tth3w's Avatar
yeah adding oil to the studs will definitely mess with the torque on the studs. so double check that.
Old Nov 3, 2013 | 04:51 AM
RezinTexas's Avatar
Gents, completely agree that only ARP lube should be used on the M11x1.0 threads when torquing down the heads. This ensures that the nuts are subjected to the correct friction forces and the correct clamping force is achieved.
Oil on the M11x2.0 block side threads, a little oil is acceptable if you're having trouble twisting in the bare studs to the block by hand.
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
4B11T
Jul 13, 2015 03:48 PM
ChevyLee
Jul 10, 2015 10:56 PM
NuckenFuts
Jul 9, 2015 08:45 AM
