Arp head stud questions unanswered
Old Oct 26, 2013 | 08:02 PM
Yukon04's Avatar
Default Arp head stud questions unanswered
Everyone says use the search well how about the search leads you to posts with 100s of different answers so would someone clear the air and tell me, when installing arp head studs into a lq4 do you install dry? Lubed? What's the tq 70? 80? What's the patterns? Someone who's installed with success please chime in I'm in the middle of a build and I'm tried of searching and reading 10 different answers
Old Oct 26, 2013 | 08:22 PM
Yukon04's Avatar
Anyone?
Old Oct 26, 2013 | 08:23 PM
skeet's Avatar
check about 2/3rds the way down youll see it, pretty simple well explained
LS1Howto.com
Old Oct 26, 2013 | 08:33 PM
GMCtrk's Avatar
The ARP studs should come with instructions. If they didnt, you can get them on their website.
Install the studs dry hand tight and torque down the bolts using ARP moly lube. 30-50-80 lb/ft on the large studs.
Old Oct 26, 2013 | 08:41 PM
Yukon04's Avatar
Install the studs hand tight the torque down the bolts? I have studs not bolts.... You mean nuts and washers?
Old Oct 26, 2013 | 08:44 PM
thunder550's Avatar
High on diesel fumes
Yes, studs dry and hand tight. Then nuts with assembly lube to specified torque, usually in 2-3 smaller steps.
Old Oct 26, 2013 | 08:55 PM
Yukon04's Avatar
Got it thanks....
Old Oct 26, 2013 | 08:58 PM
GMCtrk's Avatar
And make sure your head bolt holes are dry and free of debris.
Old Oct 28, 2013 | 04:19 PM
RezinTexas's Avatar
you can put a little oil on the block threads, it makes no difference in the end. My block threads had some light surface corrosion and the oil helped me to thread them in. Hand tight only, as others have said.
Old Oct 28, 2013 | 04:22 PM
Atomic's Avatar
I have a gauge for that
Oil is ok, water is not ok. Make sure you blow out all the stud holes before threading them in.
