Anyone using 862/853/806 notched heads
Old Aug 23, 2017 | 12:17 PM
RPMSpeed Tech's Avatar
Truck Sponsor
Default Anyone using 862/853/806 notched heads
Any guys in here using the GM notched heads? Normally the 862/853/806 castings? I realize not all of those castings have notches on the deck, but what head gasket are you using for them, or are you having the deck welded then milled down to use a reg gasket?
Old Aug 23, 2017 | 12:39 PM
Mean Green z28's Avatar
11 Second Club
weld and mill is the only way to guarantee it and be able to use a MLS gasket instead of the graphite. I think Felpro has a MLS that'll work on the notched heads, but I don't have experience with it to recommend.
Old Aug 23, 2017 | 12:45 PM
Truck Sponsor
That USED to be the only way. Until now. We have mls gaskets specifically made for notched heads. One set will fit 4.8/5.3/5.7 and the other set will fit 6.0 and even 6.2l blocks. In case someone has a nice pirted set of heads and do not want to buy another set etc or port their stock set.
They are much cheaper and the only other mls set out there with the notch from felpro.
The 4.8/5.3/5.7 gasket set is $50 and the 6.0 set is $70.
.053 compressed thickness as well.
Since gm got rid of their composite gaskets for the 4.8/5.3/5.7 in both separate and the gmpp 12498543 we knew we had to do something and we decided mls design was better than any fiber or composite gasket.
Old Aug 23, 2017 | 02:00 PM
Truck Sponsor
This is what the ls1 style looks like. Notice the 2 notches on the center 2 cyls. They are universal side to side.
And here are the links
6.0 gasket set
Old Aug 23, 2017 | 02:57 PM
wretched73's Avatar
Did you write the first post just so you could write that exact come back?
Old Aug 23, 2017 | 03:02 PM
Truck Sponsor
No. I am interested in the guys running those heads and why of course also. His reply did set it up, but i was not expecting that.
