Anyone think an STS/Radix would work?
Originally Posted by moregrip
yep. I mean turbocharged and blown!
I know on old school diesels this was the "hotrod setup".
I'm thinking it might be possible..........whada ya think?
Volvo Penta uses a supercharger that is clutch driven like the clutch on an AC compressor. It stays ingaged till it hits 1800rpms, then it switches off and a valve is blown shut by the turbo boost. Then the turbo takes the rest of the rpm range. The desiels with this setup in boats is awsome. They take off like a rocket, and run at 4500rpms making 35psi of boost.
Even though its been done, and can be adapted to a truck its really not a good idea. A well chosen turbo will make boost realy quick, and have very little lag.
Interesting concept. It would be cool to see it successfully done on an LS1 engine. I agree with the previous comments - there would be air flow limitations and extensive custom fabbing and tuning.
If you could fab a clutch-operated pulley for a Radix, you would probably find some customers. Maybe a custom "Mad Max" button for the dash to activate the clutch...
Looks like somebody has the beaten you to the punch. See what happens when you don't listen to nasayers. A true custom motor!!!
https://ls1tech.com/forums/showthread.php?t=181191
Stainless Works
Apr 10, 2016 04:34 PM
atxlt
Jul 20, 2015 11:06 PM
Nimoryan
Jul 5, 2015 03:50 PM
