anyone pull the AC? how much weight are we talking about?
Old May 1, 2004 | 12:44 PM
Also, what kind of tires are you runing? Even AWD on stock tires can only hold so much HP.
On second thought, maybe you should let off the N2O when you max the MAF.
Sorry, but one more thing. What the hell does the track people say when you run these 11s with no cage or harness?
Old May 1, 2004 | 12:58 PM
parish8's Avatar
single digit dreamer
hey snake eater, did you just read my post in the FI section, i asked the same question as you about the 35shot or more boost.
tries hold a low 1.7 without a squeek, i think they will hold a low 1.6.
they all like my truck at the track but wont let me run over and over, basicly let me run once and say slow down, then i can run again before they tell me to leave. i can let off right after the 1/8th though as many times as i want. i figure i wont even go for it till i can pull a 6.99 1/8th, then give it the glory run.
Old May 1, 2004 | 12:59 PM
MacADaYear's Avatar
"Was that a JET?"
Old May 1, 2004 | 01:07 PM
No, but what did they say? I say not to run more boost on the 6.0. IMO the 35 shot would work better and be safer.
High AITs=Detination=
Old May 1, 2004 | 02:34 PM
LOW2000's Avatar
Much of the AC system is aluminum, the compressor is going to be probably as heavy as all of the rest of the AC components combined. If you were going to get really crazy, lose the stock fuel tank and just run a 5 gal cell, that stock tank is HUUUUGE.
Old May 1, 2004 | 10:30 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I don't know if you are talking about leaving the truck "that" way, or returning it to stock. I would consider a fiberglass roll pan in place of the rear bumper and maybe a carbon fiber hood (or fiberglass) painted factory color. I've seen them on ebay (flat stock appearing hoods) in the $300 range before. Also, have you seen the lightweight tailgates that are options on the 2004's. I think they are like 30lbs ??? lighter. I know you remove it totally at the track but on the street it would be nice. I wouldn't remove the air conditioning (just my opinion) although I did on my street/race car and it was near 70lbs. The compresser and condenser is what made up most of the weight. Good luck, with all of the input and R&D you've done for all of us on this site I'm pulling for you to be the first to the 10's. (even if it goes boom on the way!) Thats one thing I can say, you ain't scared!
Old May 1, 2004 | 11:02 PM
I'd just remove the compressor (I would think it would be the heaviest component) and any other parts that could easily be reinstalled. ripping the evaporator out from under the dash for 5 pounds is to me
Good luck either way
Old May 1, 2004 | 11:31 PM
mwalls54's Avatar
Need More N2O Mod
i would say ac stuff under the hood should weight around 50lbs, i am with ben front sway bar and pass seat, front shocks?? windsheld wiper arms. anything you see that can be poped off and back on in mins.
Old May 1, 2004 | 11:43 PM
BigTex's Avatar
I agree with running the dual stage. Hit it hard out of the hole with two stages for 100-125 total, then pull out of one stage and leave a small 35-50 shot on the rest of the run. You get your had 60' times with the big shot, and gain the 40 hp you are asking for.
Pull both front and back bumpers.
You need to get a SS front bumper cover and a rear roll pan. The cover is pretty thin plastic. Chop the front bumper down to a skeleton, or weld up a lightweight frame to support the cover. It wouldn't be for protection anymore, just looks.
Old May 2, 2004 | 05:33 AM
Thats a good idea. I dont think the stock bumper gives much protection anyway. Anytime you hit a Honda going 20mph and do $7k in damage to your truck, and only $400 to the Honda, something is wrong.
