anyone know how to jump relays and bypass VATS system?
Old Sep 29, 2005 | 11:11 AM
treyZ28's Avatar
Default anyone know how to jump relays and bypass VATS system?
just as the subject says. i have no power to my starter
Old Sep 29, 2005 | 11:42 AM
rgvsierra's Avatar
judging from your other post, you get no cranking at all, i wouldent think thats has anything to do with vats,
vats will let you crank but not start if i remember right. i may be wrong
edit,
i read some more of the other post, if you are saying that it wont crank with the regular 4.8 computer, then i'd look somewhere else other than the vats.
Old Sep 29, 2005 | 11:45 AM
02sierraz71_5.3's Avatar
your right and the only way to disable it is through the pcm
Old Sep 29, 2005 | 12:09 PM
Nick™'s Avatar
doesn't the starter need to be bolted in place to establish a good ground?
also check your ground straps.... a bolt screwed into aluminum heads is NOT a good ground (just in case )
Old Sep 29, 2005 | 01:10 PM
treyZ28's Avatar
jesse (wait4me) and bryan at pcmforless said it CANT be disabled through PCM because its a BCM deal or whatever.
the starter is still touching the block.
nothing is grounded to the heads.
FlowmasterMufflers
Nov 24, 2015 01:00 PM
Superman09
Sep 25, 2015 05:55 AM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
chevstang421
Sep 10, 2015 09:16 AM
