anyone installing free flow cats
dealership would not touch them since they said my exhaust had been altered. true duals.unless they can bolt it on they will not touch them.i had a local muffler shop put on two dynomax small cats.
The Magnuson-Moss Act
Protecting tweakers, tuners, and other users of aftermarket equipment.FANNING FEARS
You want to upgrade your vehicle with aftermarket equipment, but you’re worried about putting the vehicle’s warranty at risk. It’s no wonder. How many times have you heard somene of a dealership say that installing aftermarket equipment automatically voids the warranty? This common misconception has been repeated often enough to be widely believed – though it is completely false.
Fact: Dealers don’t like warranty work, because it pays less than normal repair work. By promoting the myth that aftermarket equipment automatically voids warranties, some dealers avoid such low-paying work. Instead, they attempt to charge customers the prime service rate for work which is rightfully done under warranty.
THE TRUTH
Most vehicle owners are not aware they are protected by federal law: the Magnuson-Moss Warranty – Federal Trade Commission Improvement Act of 1975. Under the Magnuson-Moss Act, aftermarket equipment which improves performance does not void a vehicle manufacturer’s original warranty, unless the warranty clearly and conspicuously states that aftermarket equipment voids the warranty. Most states have warranty statutes, as well. Which provide further protections for vehicle owners.
In other words, that means a dealer can’t wiggle out of his legal warranty obligation merely because you install aftermarket equipment. To find out if any aftermarket equipment automatically voids your vehicle’s warranty, check the owner’s manual. It is likely the language you are looking for appears under a heading such as “What Is Not Covered” Although the language seems negative, remember your vehicle manufacturer is simply saying he does not cover the aftermarket products themselves. He is not saying that the products would void the vehicle warranty.
VEHICLE DEALERS OBLIGATIONS
Suppose your modified vehicle needs repairs while still under warranty. Without analyzing the true cause of the problem, the dealer attempts to deny warranty coverage. He made his decision simply based on the fact that you’ve installed aftermarket equipment – a convenient way to dodge low-paying warranty work.
An example of how ridiculous this can get is the man who was denied warranty coverage by a dealer on his power door locks, because he had improved his exhaust system! Sounds nuts? It really happened – because that man did not know his rights and challenge the dealer’s decision.
Fact: A dealer must prove – not just say – that aftermarket equipment caused the need for repairs before he can deny warranty coverage on that basis.
YOUR RIGHTS
Point out to the dealer the provision of the Magnuson-Moss Act- Require that he explain to you how the aftermarket equipment caused the problem. If he can’t – or his explanation sounds questionable – it is your legal right to demand he comply with the warranty.
Fact: If you are still being unfairly denied warranty coverage, there is recourse. The Federal Trade Commission, which administers the Magnuson-Moss Act, monitors compliance with warranty issues. Direct complaints to the FCT at (202) 326-3128.
DODGE MOTORS
“Certain changes that you might make to your truck do not, by themselves, void the warranties described in this booklet. Examples of some of these changes are: installing non-Chrysler parts, components, or equipment.” – 1997 Warranty Information supplement to Dodge
Owner’s Manual:
GENERAL MOTORS CORPORATION
“If a Chevrolet part fails due to a defect in material or workmanship not related to (on aftermarket products) or the labor to install it. Chevrolet would be responsible for covering the failed part.” – Chevrolet Customer Assistance Center
FORD MOTOR COMPANY:
“Installation of a non-genuine Ford item does not, in and of itself, render warranty void.” – Ford Owner Relations Division
FEDERAL LAW
‘In order to improve the adequacy of information available to consumers, prevent deception, and improve competition in the marketing of consumer products, any warrantor warranting a consumer product to a consumer by means of a written warranty shall. . .fully and conspicuously disclose in simple and readily understood language the terms and conditions of such warranty. Such rules . . . require inclusion in the written warranty of any . . . exceptions and exclusions from the terms of the warranty.’ – Magnuson-Moss Warranty & Federal Trade Commission improvement Act. Section 2302(a)
Formerly one92rs
that is true.but the dealer has the right to tell you know if they have to modify the new part for your vehicle.they do not and will not modify new parts under warranty to install them if you have altered a factory part. i had true duals on it so i altered a factory part. altering any factory part is prohibited.all bolt ons are legal unless they cause the problem. but if you alter factory parts then you eat them.since i altered it by putting on aftermarket cats they have a right to refuse to repair the oxygen sensors since i altered a factory y pipe which comes as a assembly.
05GMC4.8
Aug 7, 2015 09:55 PM
BIGD4504
Jul 28, 2015 11:46 AM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
