Anyone have the FMS FM13 cam?
Old Oct 12, 2007 | 07:54 AM
ramdaspadhye's Avatar
Default Anyone have the FMS FM13 cam?
226"/230" .575"/.595" 112LSA
Considering running this cam if I'm able to get this 2000 Chevy RCSB. Will have a 5.3 (for now), 3k stall, and possibly 4.11's.
Old Oct 12, 2007 | 08:06 AM
bluecajun5.3's Avatar
11 Second Truck Club
don't know were you got your spec'd out numbers from but the F13 cam specs are...
230"/232" .595"/.585" 112LSA
that's way way way!!! too big for that 5.3
but hey you could be different from the proven performers out there.
Old Oct 12, 2007 | 09:18 AM
circusboy's Avatar
those specs are for the FMS F6. I wanted the F13 for my formy, but ever cammed it.
Old Oct 12, 2007 | 11:02 AM
I hope that wasn't meant to be demeaning. I was going to swap in the 6.0 later, and wanted to get a cam that was good for the 5.3 and the 6.0. I realize that it's a larger-than-average cam, but being a RCSB, i figured it would be okay. What else would you recommend? WHat would you suggest as the largest cam for a 5.3 with a 3k stall and 4.11's?
Old Oct 12, 2007 | 11:11 AM
ok...
first off, what are you intentions with the truck... ie DD, street/strip, weekend, etc...
there was no mention about a 6.0 in the future.
your right it's a large cam for a 5.3, also for a 6.0 in a truck.
max would be a 224 with that size converter and 4.11's. should work good with both engines.
Old Oct 12, 2007 | 12:40 PM
circusboy's Avatar
Old Oct 13, 2007 | 09:17 AM
14 Second Truck Club
I've got one on a 114+4 LSA in my 383 LS1. I couldn't be happier! Awesome driveability and power everywhere. I wouldn't put it in a 5.3. I would with a 6.0 and LS6 intake to take advantage of the powerband. My truck intake is choking the hell out of mine past 5K rpm. I've got a vengence-ported 90mm FAST going on next week to top my motor off. Should pull hard to the 6300-6500 rpm range. Trust me, this cam has awesome power potential. There is a bunch of dyno graphs over on ls1tech that show the torque curve and it pulls hard and sounds awesome, even on the 114 LSA.
Old Oct 13, 2007 | 09:40 AM
Quik's Avatar
5 year bitches!
3k stall is way to small for most cams above 220!!!!!!!!!!!
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
