Anybody using a valve cover "Breather"?
#21
Originally Posted by 4.8T
if you don't have it going to the intake at all i don't see why not put one on both sides that way it can vent as well a possible. old school eng have them on both.
#22
Great topic guys.
I would like to know if I can eliminate the line going back to the TB from the passenger side valve cover. My STS kit has a solenoid control valve there so I'm not sure if it needs to vent back to the TB or not.
I do get some substantial oil comming out of the filter I have on there now.
Enough to need some type of catch container to keep it off my exhaust and everything else.
Here is a pic of my set up.
That little filter is dry in these pics but soaked with oil and dripping all over everthing now. I'm going to rig up something temporary for now.
#23
Originally Posted by 02sierraz71_5.3
you can do that but I didnt bother with it as the other crankcase vent that leads to the TB doesnt have vacumm nor does it suck up oil.
So does the passenger side vent even need to go back to the TB or can I just block that retun port on the upper passenger side of the TB off, and vent the line to a filter or catch can?
#24
Originally Posted by Kano
Im a little confused with this statement
please clarify your thoughts on how the pcv system and pcm communicate
I dont see where they do
Well Kano, to be more honest about it than I'd really like to be in public, I'm a little confused as to what the **** I was thinking at that point. My ignorance really came to the front & center. It somehow just didn't seem right to me to open up that system but what that gut feeling has to do with the puter I can't imagine. Thanks for saying that you were a little confused... as opposed to just frankly telling me that I was being stupid
Later Jim
#25
Originally Posted by TG02Z71
So the drivers side with the PVC is the bitch that send oil back into the intake? That is just plain dumb on GMs part. There should be some type of oil reclaiming vessel that filters it back into the engine not just burn it up in the intake!!
Then as engine speed decreases and the crankcase pressure subsides gravity kicks in and the oil is drained back from the puke tank to the valve covers. It works very well. No PCV valve required. Usually the puke tanks were run in pairs or some would mount a single tank with 2 inlets and one vent. They would usually vent from both valve covers but this not absolutely necessary.
See attached pic of a dual inlet puke tank. Notice the valve covers in the rear of the photo. I think you can figure out the rest. Not complex at all, but a proven design and very effective. Can be mounted just about anywhere above the valve covers
#26
[QUOTE=smooth sierra]you need what is called a 'puke tank'......old school again but let me educate some. Once upon a time.......high reving boat engines and drag engines, especially ones that were supercharged would run puke tanks. These are basically small tanks (say maybe 1/2 a quart worth of volume or less) with a inlet, usually on the bottom or on the side of the tank and an outlet on top of the tank with a filter on it. This tank has to be mounted above the valve covers. The theory behind this setup is as follows. When the engine is reving high and there is a large amount of positive pressure in the crankcase the oil is pushed out of the breather tube into the puke tank where it can accumulate. It does not however come out of the filter on top of the tank or you have bigger problems.
Thanks for the schooling, Looks like something I can make myself without too much trouble.
Just a canister mounted above the valve cover so it can gravity drain back to the engine but also open so it can breath.
A stainless mesh filter inside would help slow down the puking effect under high or sustained boost levels, no belching out the vented area.
#27
Great topic guys.
#28
maybe i missed it but do you have just stock pcv on the driver side still going to the intake if so thats where you get a problem you turbo will cause postive pressure in the manifold and will charge you crank cause cia your pcv those don't hold pressure back from what i can tell and it will cause more pressure and cause it to come out you passenger side
No emmisions in my county....good for me I guess.
#29
Everything clear as dirty oil on your engine?
#30
Its all clear Jim, I was planning on leaving ths STS control valve on there, just encasing the puke line into something to catch and return the ralphed up oil back to the engine.
Thanks guys.
And thanks for starting this thread, it could not have come at a better time.
Thanks guys.
