any1 swaped a 6.0l in a 88-98???
Old Jan 15, 2012 | 12:01 PM
BOWTIE-TIL-I-DIE's Avatar
Default any1 swaped a 6.0l in a 88-98???
Ive had my 98 c1500 for 14 years now and I reaqly want to drop in a v8. (v6 is all i could afford when i was 20) I am debating on a 5.7 with heads and cam or a 6.0. I know the A/C compresor wont fit but i want A/C for sure. do I notch my frame or sell an arm and leg for a serpintine system that would relocate the compressor
Has any1 done this? im sure its been done a million times but has any1 on this site done this conversion? this is also my daily driver, still, so this cant be a year long project. thanx in advance
Old Jan 15, 2012 | 03:48 PM
1994Vmax's Avatar
www.LS1truck.com. Check out the LSX Truck Conversions swap section as it's probably 85% 88-98 trucks. It's where I go if I get stumped on my 94. There is a sticky at the top that goes through the swap step by step for a Gen 1 Vortec truck like yours.
Old Jan 15, 2012 | 05:53 PM
Slammed96's Avatar
+1 on LS1truck.com, lots of good information and lots of good guys over there. They can help you do a swap without spending a small fortune. Good looking truck by the way
Old Jan 16, 2012 | 07:47 PM
thanx guys, i realy appreciate it. now i can sleep peacfully....after i research for 2 days straight now, j/k
Old Jan 16, 2012 | 08:20 PM
SCOTT_A's Avatar
I did the 6.0 swap from the v6 in my 95. Totally worth the effort. Ls1truck has a lot of info. Let me know if you need help.
Old Jul 27, 2016 | 01:08 PM
Ryan2real's Avatar
Registered User
Default Can u help me out
Hey man I need help on what do I need to do a 6.0 swap on a 98 chevy
Old Jul 29, 2016 | 07:34 AM
gagliano7's Avatar
I have a 5.3 in a 1992 pickup(same dimensions as a 6.0). I have a dirty dingo bracket for my a/c, stock location high on passenger side. I know the 1998 has the compressor opposite side of mine but there is a bracket for yours that keeps it in your stock location. There is also only 10 wires you need to switch around to use the 6.0 gen 3 411 pcm on your swap. It will go right in place of your PCM.
I am building my 6.0 to put in next spring.
Old Jul 29, 2016 | 10:19 AM
89sierra's Avatar
it all depends on how crazy you want to get. what exhaust you want. what transmission you want to run.
is your truck 2wheel or 4 wheel drive?
Old May 1, 2017 | 02:38 PM
pigfarmer's Avatar
I'm swapping my 97 Silverado with LQ9. Which is better, drive by wire are cable? What do I need.
Old May 2, 2017 | 08:10 PM
Fast355's Avatar
Get the Lextech brackets and mount your factory a/c compressor in the stock location.
