Any Exhaust Gurus Around Here?
Originally Posted by 02denali
you know i got tired of the drone as well. i have gutted cats which makes some more noise. i went to two dynomax super turbos and yes in town it can be a little noisy at times. but it is dead quiet on the freeway though. are you after the facory quiet. if so if you ever find it and it works out i wanna know. i think i would love to be silent--but deadly/
I am interested in this also, I have the catback he tested with a set of Dynatech headers and the noise is getting old. I am with 02 on this one, silent but deadly. I was thinking of going back to stock also.
heck yay. a little rumble but a stock sound would be kick ***. i would even leave my tailpipes in as well. it would just be real quiet. i know cats will help but i am running strong withoput them right now.
I have the new "6.0 cat-back Flowmaster" on my '02 Denali and it sounds absolutely perfect. I talked to the tech over there and they said the 6.0 is by far the most impossible motor to get the "right" tone with no drone. Guess what, they nailed it. There is no question in my mind that this is the best sound I could have asked for. It comes with a resonator and a 50 series mufler, and a 4" tip. Very nice setup.
Now, my problem is I have to take it off in a couple weeks for the STS kit!!!
Originally Posted by Mort
OK maybe??? But no right angle bends in the pipes. A x-pipe would likely be beneficial as mentioned. The HD muffler must be similar if not identical to your stock muffler.
Does your Magnaflow have the resonators in front of the muffler? If not I think you may be able to add the resonators from Magnaflow but I don't know if that will cure the resonance for you. Try Magnaflow and see what they have to say.
Yes, my Magnaflow had the resonators before the muffler, but it still was pretty annoying (to me, anyway) on the freeway, especially on long trips. Interestingly the drone would quiet down after about 80 mph, but that is not too practical on long trips, unless you like to meet the local CHP
Have you really considered what performance gain you would lose if you ran the factory exhaust? I bet my Magnaflow cat-back only picked me up like a tenth....two at the most. If it bothers you that much I would just run the stock set-up and see how it runs with that. My Magnaflow bothers me at times, but usually it isn't that bad. I did loosen up all of the clamps and pull the tailpipe as far away from the body as I could...like an inch and 1/4 gap between the tip and the bed of the truck. Believe it or not this helped with some of the resonance that I was experiencing. Anything aftermarket set-up that offers a signifigant gain in performance is going to make more noise...I convinced until prooven otherwise.
I own The exhaust shop in birmingham, I've had good luck installing X-pipe, 2 magnaflow # 12256's 2 1/2" tail pipes and tips not over 3" in diameter. You don't get the resonance near as bad and it's not raspy like the dual in dual out . Sounds great.
