Any benefits from removing EGR ?
Old Jan 10, 2003 | 01:54 AM
Ryan23silverado's Avatar
Default Any benefits from removing EGR ?
Would there be any loss/gain in power from the removal of the EGR equipment? I have a 208/216 .500 cam if this makes a difference with the longer duration cam. If there are no negative side effects to this I think I will remove the EGR stuff. LS1edit will be here next week <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jan 10, 2003 | 11:32 AM
BigKID's Avatar
Default Re: Any benefits from removing EGR ?
I cant tell much SOTP difference from removing mine but it will keep everything topside of the motor a lot cleaner. That has got to amount to something over time.
Old Jan 10, 2003 | 11:26 PM
parish8's Avatar
single digit dreamer
mine is gone, geting rid of the ugly thing is probably the bigest benifit but who knows, not having a tube blocking the incoming air has to help a little. also with a whipple it is alot easier to mount without the egr there.
with ls1 edit i went thru and turned off all the tests for the egr but still got a ses light. i had to go into the "does error set ses" and turn those off also, the actual words are "type x = turned off" once i did that no more ses lights. you will see what i am talking about when you get it.
Old Jan 11, 2003 | 01:02 AM
Cool, thanks guys. My buddy told me that removing the EGR raises combustion temps by a couple hundred degrees. This can lead to knock, which is understandable, but is he correct? We were also wondering if my cam would allow for "enough" exhaust gas recirculation on its own because of the 113lsa the exhaust valve and intake valve would be open at the same time for a longer period than they normally would be with the stock camshaft - thus some exhaust would be in the incomming air charge (like an EGR does). Any ideas on that? or does the EGR equipment put in LOTS of exhaust into the combustion chambers more so than could be made up with the new cam?
Old Jan 11, 2003 | 04:02 PM
gonzo 6.2's Avatar
Parish
Is there a plug you can buy that will fit perfect to block off the EGR?Is it a GM part #?
Pimpinpete
43
Dec 22, 2017 08:13 AM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
Pimpinpete
Sep 8, 2015 07:39 PM
