anti seeze
Old Dec 26, 2004 | 08:22 AM
NateZ's Avatar
Default anti seeze
Do i need to put alittle anti seeze on the plugs before i install them?
Thanks,
Nate
Old Dec 26, 2004 | 08:29 AM
one03sierra's Avatar
Formerly one92rs
Talking
that wouldnt hurt. makes it easier to pull out later.
Old Dec 26, 2004 | 10:19 AM
parish8's Avatar
single digit dreamer
i do, and on my 02's also, hell i put it on all exhaust bolts but on a turbo those bolts have a way of locking up.
Old Dec 26, 2004 | 11:16 AM
BlownChevy's Avatar
blownerator
25 Year Member
Thanks,
Nate
If you ever want to take them out, you will!
Just dont get crazy with it....a little goes a long way.
Old Dec 26, 2004 | 04:35 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I dab some on the very top of the thread (farthest away from where the spark happens).
Old Dec 26, 2004 | 05:15 PM
litreddevil's Avatar
Banned
just watch because to much can cause a miss due to bad ground I don't new truck have alum. heads unless running very compresstion don't need to tighten up that much
were they would get stuck
Old Dec 26, 2004 | 05:22 PM
NateZ's Avatar
How much should i torque them??
Nate
Old Dec 27, 2004 | 01:40 PM
04BlackGmc's Avatar
10 Second Club
Anti seeze is always good especially with Aum heads.
Old Dec 27, 2004 | 01:48 PM
moregrip's Avatar
what a rush!
Thanks,
Nate
anytime you have dis-similiar metals antiseize or other lube is a must.
I am a big believer in this. My dad has been in the hardware busines 40+ years and having two different metals will corrode in every case.
Old Dec 27, 2004 | 05:12 PM
ktmrider's Avatar
Nate
15 ft/lbs max with brand new heads, else 12 ft/lbs normally.
Definitely invest in the anti-seize, you will appreciate it on the next plug change. I use it on everything near heat or when going into aluminum.
DrX
Sep 18, 2015 08:53 AM
OrlandoFL4.8
Jul 7, 2006 07:17 PM
2003Silvyrado
14
Oct 8, 2003 02:17 AM
