Answer from Pro Cold about using the OEM intake tube.
I e-mailed Dave from Pro Cold about why they are using the OEM intake tube with it's baffles & resonators and here's his answer.
"The reason we as some other intake companies have decided to use the stock or stock type intake tube with an air muffler is that we actually got less HP from a straight tube.
The intake tubes with air mufflers help correct turbulences and also aid in having some extra air available so when you go to WOT or gas it a bit it is more responsive because it has some back up air.
We could have made our product with a nice anodized piece to make it look really cool but “form follows function” around here and we just wanted to make power the best way possible."
Now this makes sense to me and AirAid has told me the same thing. Some may still disagree but I for one am satisfied with his answer.
Jim
Jim
makes since but i still dont believe they LOST performance thru a straight tube...and those extra baffles are there to quite the intake down and to provide extra air..I just dont see how the stick carries more velocity then a UPD tube
Not a flame, but it is possible that the GM engineers put more than sound concerns and tip in air supply into the equation for the air intake tube. It is quite possible that it is a tuned tube and the resonation through that tube actually smoothes the airflow instead of causing laminar shearing of the fluid through a smooth pipe. (yep, I said fluid in reference to the airflow, chew on that)
Jim
Jim
heck thats like saying, why port heads, leave all those extra restrictions in there..
Originally Posted by Fast4.8
Same thing AirRaid told me a few years back. Hmmm....Airraid makes their own tubes now though.
Jim
Banned
ok, interesting BUT....when i went from stock intake to a UPD i got a TONNNNNN of throttle response from it, and now i'm back to a volant box with a stock tube and the throttle response is back to zip like it was before. so i had better response and power with the strait tube. maybe it's a case by case basis type thing, and weather and climate could have some play in it also.??????????????/ who knows.
Suburban2500
Jul 14, 2015 02:10 AM
