Another Injector Question...
Old Apr 1, 2010 | 09:24 PM
budhayes3's Avatar
PT's Slowest Truck
Default Another Injector Question...
Allrighty, I just sold my 31# 8.1 injectors as it seems that they would be maxed out from what I've seen with other guys with those injectors and similar, or milder set ups then I'm planning...here's the specs:
LQ9, WCCH StageII 317's, 220/224 .575/.575 112, truck intake, SW LT's, etc...
I'm thinking that the 8.1 42# Marine Injectors are the only plug and play option for me, I'm just worried that they may be too big for my combo....seems like something in the 36-38# injector range would be perfect, but I'm not sure...I'm just kinda guessing and not doing any math here...
So what are my options and what will work?
Thanks in advance
Old Apr 1, 2010 | 09:27 PM
00ChevyScott's Avatar
Wearin' da big hat
FWIW I'm running 8.1 marines and have no problems.
Old Apr 1, 2010 | 09:28 PM
GMCtrk's Avatar
why would they be too big? They'll be perfect. I have a new set I'll be dropping in tomorrow myself.
Old Apr 1, 2010 | 09:30 PM
hirdlej's Avatar
Why would they be too big? They're actually perfect. That's what I run in my setup. At 6200rpm I'm hitting about 67% duty cycle. Anything over 80% and you're starting to "over drive" your injectors. Get the marine injectors and don't look back
Old Apr 1, 2010 | 09:40 PM
budhayes3's Avatar
PT's Slowest Truck
Thanks guys...as far as "too big", if your IDC is too low, you may not have a perfect spray at lower RPM's which will not allow for a perfect combustion...just a little theory, you know how I like everything perfectly "matched" I may be digging a little deep, but I'm a little kooky that way.
Old Apr 1, 2010 | 09:44 PM
Wearin' da big hat
Just looked at an old log of mine, my IDC % is at 73% at 6700 RPM haha, but my truck does run a bit rich WOT
Old Apr 1, 2010 | 11:11 PM
budhayes3's Avatar
PT's Slowest Truck
That's in a 5.3? Sounds like the 8.1 marines will be fine for me
$A_Money$81
Mar 27, 2023 10:25 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
shootermwc
Oct 8, 2015 01:45 PM
sTNT971
Sep 26, 2015 04:22 PM
andrewlong
Sep 8, 2015 10:25 PM
