Another Fuel Pump Thread
Old Feb 4, 2008 | 09:12 PM
MikeGyver's Avatar
Default Another Fuel Pump Thread
I'm running out of gas. The fuel pressure starts dropping at about 4000 rpm, down to 42 psi by 5000 on a WOT run, and the AFR starts leaning out at 4000. Full tank. I installed a new stock pump/bucket assy. last summer. With my new engine, I put in a new filter, and a brand new MagnaFuel 4301 inline. I replaced another 4301, it somehow got noisy during the motor job.
Does anybody have a similar set-up? I can't believe that the stock pump or bucket is acting as a restriction.
Old Feb 4, 2008 | 11:59 PM
Hawk179's Avatar
Its a pressure problem. Put a Bosch 044 pump inline off your main line and you should be fine.
Rick
Old Feb 5, 2008 | 12:18 AM
MikeGyver's Avatar
Are you saying the MagnaFuel is a P.O.S.?
Old Feb 5, 2008 | 10:13 AM
Hawk179's Avatar
no, just sounds like its not working for you.
Have you tried just a solid intank 420 pump yet? Thats what I run.
Rick
Hawk179's Avatar
Also, couple things could be happening.
What gauge are you using for fuel pressure?
At what MAF Hrtz value are you dropping AFR?
rick
Old Feb 5, 2008 | 10:51 AM
MikeGyver's Avatar
I'm using a Johnson Controls P399AAC-1C. It has the same characteristics as the Autometer, it was just cheaper for me.
I'm running 2-bar SD, pressure starts dropping at 150 kPa.
Old Feb 5, 2008 | 11:23 AM
05crew's Avatar
walbro 255 and ride!!
Old Feb 5, 2008 | 05:27 PM
MikeGyver's Avatar
What is a 420 pump?
Old Feb 5, 2008 | 10:54 PM
MikeGyver's Avatar
Are there known issues with the MagnaFuel inline pump that claims to support 1000 HP that are unknown to me?
Old Feb 5, 2008 | 11:36 PM
Hawk179's Avatar
What is a 420 pump?
Bosch
