Am I wasting my time with the stock catback?
Eventhough I have a magnaflow "straight thru" muffler welded in, when I cap my cutout my low end just goes to ****. I'm not a physicist or anything, but in medicine when talking about the vascular resistance, the single most important factor in resistance to flow is the radius (of the pipe in this case). It's in the denominator to the 4th power. So even a small change can make a big difference. Length of the pipe also plays a factor. What I'm trying to figure out is will going to a 3.5" catback get me the same power as my cutout? Is the magnaflow muffler killing power? So theoretically going from the stock 2.75 to 3.5" cutout will offer a ~260% decrease in resistance to exhaust flow. I'm curious what everyone else is running after the 3" Pacesetter Y pipe. Thanks!
While I don't have a Pacesetter Y, I have the following to say. Who offers a 3.5" catback? Most of the usual systems are 3". Not the diesels, they're BIGGER!
A 3" should fit your needs. Going too large kills torque. Not what u want to do on a truck, unless going for sound. On a truck, u don't want horsepower, u want torque. Torque moves our heavy trucks.
Let's think about this for a second, if you have more resistance to removing exhaust flow from the combustion chamber (what you are calling "backpressure) you are increasing the resistance to piston movement. Thus, the crankshaft isn't rotating as forcefully. Your power output goes down. As far as I understand it exhaust flow is all about VELOCITY. So if anything, any "loss" of power with headers is due to a mismatch of too large a header primary to too small of an engine (too little exhaust coming out for the size of the pipe). Get the right sized header primary and I guarantee you that you will gain power all over the powerband just as I have experienced.
Where's the Beef?
I lost low end with mine.
I've seen dyno runs lose 5~ hp from opening a cutout. It's not a myth, it really just depends on your setup.
At our dyno day a person was there with the same truck as mine except he had a cam, tune and Straight pipe compared to my Stock cam, full exhaust and tune. I made about 40hp more than he did.
