Aluminum blocks and 4-wheelin'?
Old Feb 26, 2004 | 08:33 AM
silent1's Avatar
Default Aluminum blocks and 4-wheelin'?
I doubt you will see any aluminum block truck engines anytime soon due to the fact that those blocks don't hold up well against the torture that a truck subjects it too. Drop an LS1 into a 4x4 and do a stream crossing while the engine is hot (4-wheeling); bye bye engine block!
I was thinking of going with an aluminum block but, now am not so sure. How true is this? Or would this only happen in extreme temp changes like, hot engine going through 35*F water? I do the ocasional four wheelin' and do go through some pretty deep water, so this does concern me. Any more input would be great.
Old Feb 26, 2004 | 09:54 AM
Flyer's Avatar
In theory that could happen to any engine. Hot metal, cold water ... somethings gonna give in that rapid temperature change.
Try this .. get a 100watt light bulb in a lamp, leave it on long enough to get hot. Wash your hands and flick the water drops on it. Be sure to do this outsie though.
We ruined a shop bulb, the $2 indestructable ones by letting some coolant drip on it.
Old Feb 26, 2004 | 11:08 AM
silent1's Avatar
I understand that but, you have to admit glass has nowhere near the flexibility of aluminium. My question really is, I guess, are aluminum blocks that prone to damage from cold water warpage or cracking?
Old Feb 26, 2004 | 11:28 AM
Seeing Red Again's Avatar
Flyer is right; it could happen to any engine. I would imagine that it would take a fairly extreme case to crack even an aluminum block. Probably something like blasting though a mudhole turning 5K rpms then splash down in some deep water.
I should point out that I don't have any personal experience with aluminum blocks; thats just what I have heard. Some of my rock crawling buds run aluminum engines to save weight, but we don't play in deep water either.
Old Feb 26, 2004 | 11:40 AM
Flyer's Avatar
I would like to add that after running through that hole at 5k rpms and before splashing in the deep hole, that the engine would probably have to be overheated as well to actually crack.
Old Feb 26, 2004 | 11:53 AM
silent1's Avatar
Thanks guys, I feel quite a bit better now.
calsdad
Jun 14, 2023 11:07 PM
gmcyukon
Oct 5, 2015 06:20 AM
Mark_k
Oct 1, 2015 11:17 PM
old motorhead
Sep 29, 2015 08:22 PM
trevorh1
Sep 27, 2015 08:47 PM
