Aluminum 862 heads..what from?
Old 08-24-2010, 09:25 PM
nickleahy23's Avatar
Default Aluminum 862 heads..what from?
My friend has had these aluminum 862 casting heads since middle of highschool, which was about 04 or so...i finally just did some looking around and it seems they are 5.3/4.8 heads? he was told they were ls1 heads...any input? we were just curious on them since they have been in the basement for a long *** time..
Old 08-24-2010, 09:42 PM
Bigschwerm's Avatar
That is correct...here is what i found.
706 & 852 & 862
Head: 1999+ LR4 4.8-liter Truck
1999+ LM4 / LM7 5.3-liter Truck
Material:Aluminum
Part Number: 12559852, 12561706 ,12559862
Combustion chamber Volume:61.15cc
Compression Ratio:9.5:1
Intake port Volume:200cc
Exhaust Port Volume:70cc
Intake valve Diameter:1.89-inches
Exhaust valve Diameter:1.55-inches
What you need to know: These small combustion chamber truck heads offer no advantage over an LS1 head except the smaller combustion chamber. This along with milling of the deck surface will allow a slightly higher compression ratio to be achieved. Because of the smaller intake valve installed in these heads a valve upgrade is practically mandatory.
Old 08-24-2010, 09:45 PM
LightFighter's Avatar
you would be better off grabbing a set of CNC'd LS6 heads that are milled to give you a little more compression
Old 08-24-2010, 09:52 PM
Baltimore Whore
Mangled03gmc's Avatar
Nothing special, as stated in the first rep. 4.8 5.3 heads. LS1 heads were 241, the ls6 heads are 243's and if IIRC 799's
Ls6 have a 64.4 cc chamber vs the 61cc chamber on them.. 243's will out flow them by alot, unless you have the runners worked, bigger intake valves added to the ones you have
Old 08-24-2010, 10:12 PM
thanks guys..i wasnt wanting to buy them, we just forgot about them and finally wanted to know what they really were lol...
BigE
02-21-2018 11:44 AM
GM1697
10-20-2015 12:12 PM
gmcyukon
10-03-2015 11:03 PM
old motorhead
09-29-2015 08:22 PM
BigKID
09-22-2015 09:59 PM
Quick Reply: Aluminum 862 heads..what from?
