Alterntor died at high rpm
Old Mar 9, 2009 | 05:10 PM
Atomic's Avatar
I have a gauge for that
Default Alterntor died at high rpm
My alternator decided to crap out when I was tuning my truck yesterday. I think it might be because I was running 6000rpm+ getting the VE table in line. Its an excessive amperage 250a model and im pretty sure nate can fix it, but is this a problem anyone else has had with blowing alternators at high rpms?
Old Mar 9, 2009 | 10:18 PM
thunder550's Avatar
High on diesel fumes
I had one do the same thing. Starting smoking and ended up catching on fire. Aftermarket. They usually put smaller pulleys on the high output aftermarket ones to keep the idle voltage up, so when you spin your engine to a high RPM they are going much faster than an OEM one would. I think on mine I spun it fast enough that the rotor expanded and came in contact with the stator. Game over after that.
Old Mar 10, 2009 | 07:17 AM
krambo's Avatar
I was on the dyno once and reved it to 6500+ under load. When I got out of it, it threw a shower of sparks...I thought I blew the motor. This was a stocker and it turned out to be O.K.
Old Mar 10, 2009 | 07:41 PM
oldred95's Avatar
Thats weird. I put a CS144 on my 95 and once I hit 4500 rpms it stops charging until I go below 4500. I've checked all the PCM settings and the only thing it can be is the regulator shutting it off. The stock CS130 never did this. Maybe it does that to keep from letting the smoke out at WOT.
Choda
Jun 5, 2025 06:43 PM
Texas5.3_1251
Mar 5, 2016 08:10 PM
b4z
Sep 10, 2015 06:58 PM
Pimpinpete
Sep 8, 2015 07:39 PM
Boyes50
Sep 8, 2015 12:06 PM
