alternator upgrade
Old Apr 8, 2004 | 10:24 PM
Hit Man X's Avatar
Originally Posted by mudz5.3
Not sure if that would be enough for my set up, with future plans in mind. I don't like the sound of the overdrive pulley on my 105, so I figured get the biggest available, until I started searching and they make a 250 for our trucks, although its almost 500 bucks!!
250A needs an external regulator is why it's so $$$.
What's your total plans?
Old Apr 8, 2004 | 10:30 PM
mudz5.3's Avatar
The 250 is a dual rectifier set up, single package. Well right now the lights dim with the stocker 105A with my stereo. I put a overdrive pulley on and that fixed that. I will be installing LT1 fans and possibly an aftermarket airdam foglight set up. I am thinking about upgrading my stereo also from a JL8w7 to a 13w7. That alone would require a JL1000.1 and my highs would need a 300.4. So, just thinking that I don't want to have to worry about dimming of lights. I do compete now in Sound Quality so keeping the amps up is important.
Old Apr 8, 2004 | 10:36 PM
Hit Man X's Avatar
Well and all in one setup is cool.
Yes I could hurt my charging system w/ a JL 300/4 and 500/1 (XR653s up front, Kappa plates in back, 12w3v2 sub) it'd notically dim the lights w/ a 1 farad cap and a Yellow Optima on the 105A unit. Also the e-fans would undercharge me at idle when they were on.
With the extra ~20a at idle from the OE 130A unit I can get my **** to dim if I really pound it but hardly see the need to. And I have full charge with the A/C on and the fans pulling full speed.
I'd skip the ASP pulley if you're concerned with the amperage at idle, it's only good for like 8-12rwhp anyway.
Old Apr 9, 2004 | 12:18 AM
LOW2000's Avatar
I lag my system too pulling 1000W of stereo power, PIAA driving lights, in-dash monitor, V1, and my air compressor. I have AAA though, so i'll wait till this alternator dies before I upgrade.
Old Apr 9, 2004 | 12:48 AM
Originally Posted by Hit Man X
Allright peeps, the Hit Man has found the number for them...had to call up a few of my gals to dig through my files...
574-262-1850
Truck-N-RV Supply is the place. It was like $90+shipping UPS...
Enjoy!
Does this use the same bracket as the stock 105 amp? I have heard you have to buy a new bracket or fab one up, and also heard it bolts right in. Which is it?
Old Apr 9, 2004 | 01:04 AM
454SuperSport's Avatar
can you get an alternator that puts out too much power? i would like to put a 130a on my truck but the only aftermarket things i run are electric fans, 3 cobalt series guages, nitrous kit wiring, and soon to be wideband setup. would the 130a overcharge?
Old Apr 9, 2004 | 02:36 AM
LOW2000's Avatar
Nope, thats what the voltage regulator is there for, its just more load on your engine for nothing if you arent using all that juice.
Old Apr 9, 2004 | 04:28 AM
dandaman's Avatar
Are the factory wires large enough ot handle the additional amps?
Old Apr 10, 2004 | 12:44 AM
Anyone know?
Old Apr 11, 2004 | 08:54 AM
The Delco 130A and 145A alternators will fit in the 105A alt bracket, but the larger ones have a slightly bigger frame. This will move the pulley out about 1/2", and you will probably need a belt that is 1/2" longer...
TrickTurbo
Sep 23, 2015 08:41 PM
mpal
Sep 18, 2015 09:12 PM
Noah Burns
Sep 13, 2015 09:28 AM
