Alternator amperage
Old Feb 10, 2004 | 03:16 PM
Default Alternator amperage
I have a 2000 with a 5.3L, how many amps is my alternator?
My sisters truck was crashed and totaled, it is a 2003 4.8L and 4x4 would that alternator be more amps than mine??
Thank You.
Old Feb 10, 2004 | 03:28 PM
yellowls1truck's Avatar
most of the light duty truck have the 105 amp alternator.
Old Feb 10, 2004 | 04:28 PM
ThunderZ28's Avatar
12 Second Club
it should be stamped on the case of the alt. you will have to look pretty hard. its like someone took a punch and tapped it into the case.
most light duty as yellowls1truck has stated already are 105A
Old Feb 10, 2004 | 04:34 PM
FILE's Avatar
Both trucks should have a 105 amps alt.
Old Feb 10, 2004 | 05:37 PM
Hit Man X's Avatar
Almost all stockers are the 105A max... about 45A idle. The factory 130A max is about 65A idle. You can get the factory 130A on ebay for about $95 shipped
Old Feb 11, 2004 | 01:55 PM
Are the brackets, pulleys, belts all the same fit for the 130A factory alt???
Old Feb 11, 2004 | 02:01 PM
Hit Man X's Avatar
Yes
Yes
No
You'll need a longer belt. I can check my truck later today if you need me too...it's raining now and I'm at work. It's the 6.0 w/ large alt belt that you need.
drummer0415
11
Oct 24, 2015 08:16 PM
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
