Alternator
Old Aug 5, 2007 | 01:01 PM
MSD's Avatar
MSD
Default Alternator
Had e-fans installed in my 03 while it was at W2W and seen a big drop in voltage when they come on. Did the search and found that I need to upgrade to a bigger alt. My question is where's everybody getting their's from, GM or aftermarket. Thanks in advance Mike
Old Aug 5, 2007 | 01:10 PM
ramdaspadhye's Avatar
Iraggi
Old Aug 5, 2007 | 01:50 PM
TxStVanWilder's Avatar
i got mine off of a buddy that had a 145 amp..... but make sure you check the plugs cause his plug in was different than mine and i had to go to an alt shop to get a plug
Old Aug 5, 2007 | 01:51 PM
TarheelZ's Avatar
Default Here ya go!
FS: H.O. Alternator
Old Aug 5, 2007 | 03:03 PM
Holty's Avatar
Notorious BIG
do a little more research on "the big 3" before investing in a larger alt. Although i'm a big fan of larger alts, you have to upgrade your wiring to get the benefits.
Old Aug 5, 2007 | 07:25 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Had the same issue just got a 145 ALT it works great.
Old Aug 5, 2007 | 07:51 PM
MSD's Avatar
MSD
Thanks for the replys. No big aftermarket stereo or anything, just the E-fans so I'm just looking to replace the alt. Pace Performance for example has the 145 and 200 available. Should I go with the 200 or is bigger not necessarily better in this case?
Old Aug 5, 2007 | 07:52 PM
TouchOfEvil04's Avatar
I need to do this..........eventually.
Old Aug 5, 2007 | 08:28 PM
Red04Silverado's Avatar
Same here
Old Aug 6, 2007 | 09:17 AM
mwalls54's Avatar
Need More N2O Mod
the 1st one i got was at a dealership and it was a reman and last week i replaced it for a reman from advance auto.
