Alright...here's the new project....I promise !!
Old Feb 6, 2006 | 10:13 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Yelo
so I figure I'll try to drag you down here during the middle of summer to play with hot exhaust parts
Thats what true friends are for right Grip?
Traction shouldnt be a problem with the nice little 4wd button
Old Feb 6, 2006 | 10:41 PM
Yelo's Avatar
I'd LOVE to get a picture of me doing a 4 wheel burnout !!! .....THAT would be even better than stomping Grippy in the 1/4. Now....staging with a 4 wheel burnout and THEN beating him would just MAKE my year !!!!
Old Feb 6, 2006 | 11:30 PM
AintNoHo's Avatar
Man, I love all these new winter project goin' on right now. Starting one myself but not anything as adventurous as your undertaking. I wish you luck and enjoy the process.
Re the 72lbs, I'm using low impedence Accels at 70%ds with a 150 dry shot of N2O. I have no idle problem. Just a little lope from the cam.
Re the 255 Walbro, I'm using an intank and a rail pump plus a slightly bigger line. Met a killer Camaro at the drags friday, he was losing fuel pressure at top-end with 60lb Moes, 35hp dry N2O, and a 255 intank. You may need a little more.
Anxious to hear more as your project goes along.
Old Feb 7, 2006 | 12:39 AM
Yelo's Avatar
Lo-imp 72's ???.....I thought our PCM's would only support Hi-imp injectors ???
Old Feb 7, 2006 | 01:50 PM
AintNoHo's Avatar
I'm using a FAST PCM. It supports either high or low impedence. I don't know off-hand of a high-ohm 72lb but then I just recently learned of the 60lb Siemens Mototrons. It may require a low Z injector driver which I think is about $300 for an 8 cylinder.
alex226
Jul 27, 2015 07:12 AM
dewmanshu
Jan 4, 2007 07:58 AM
Scream
Feb 24, 2005 02:12 PM
