all aluminum 5.3 engine specs?
Old Jun 20, 2008 | 08:31 PM
montecarloss's Avatar
LS ADDICT/BUILDER
Default all aluminum 5.3 engine specs?
does any one know what the specs are on 07 all aluminum 5.3L,it came off a suburban,has 243 heads.is it a L33 or L59?
Old Jun 22, 2008 | 01:26 PM
Gregory's Avatar
I have a 5.3 DoD E85 in an Avalanche and below are the specifics I've found.
5.3 Camshaft
196/201 duration
.467/.479 lift
1.89/1.55 valves
9.5:1 compression
3.78 x 3.62 bore & stroke
If you check out the GM Performance Parts website it will give you the nomenclature.
Old Jun 22, 2008 | 01:28 PM
ZZebes's Avatar
Thats an L33
here are the specs i know off the top of my head
All Aluminum Block
Graffel Coated Flat Top Pistons
243 Heads
Hi-Po Cam
The rest is stock 5.3 specs
315hp rated i think
ZZebes's Avatar
and you got that truck ready for me
I'm coming for you
Old Jun 22, 2008 | 03:49 PM
LS ADDICT/BUILDER
thanks for the info.
zzebes I blew 2 transmissions, fix them, and still waiting on you.
Old Jun 23, 2008 | 05:08 PM
LS ADDICT/BUILDER
found out it,s a lc9,flex fuel engine,and cylinders deactivation. any input on compression and cc on cylinder heads?
Choda
Jan 22, 2026 02:03 PM
steves86ta
Jul 28, 2015 10:21 AM
bk_cauley
Jul 19, 2015 09:56 PM
kdw8888
Jul 9, 2015 10:52 PM
NuckenFuts
Jul 9, 2015 08:45 AM
