ALK injection guys please
Very cool. Thank you!!! That looks pretty trick. How difficult was the install?? Did you have to relocate anything to mount the tank there?? What was your total install time??
Cstchevy, ALK injection doesnt increase horsepower. It acts as an intercooler of sorts and allows you to safetly run more boost without detonation. Some use it as an added safetly measure when they are running the vehicle hard (at the track) or on hot days.
It's keeping down KR from high boost and/or timing. It allows to go higher in boost or timing without, or minimizing, KR. What I would like to know is just how much it allows you, but I guess only one way to test that. I would like to leave my boost alone, but run 3-5 more degrees of timing, or more, with one of these, above my normal setting.
As far as how it performs, it seems to do nothing for me. I am only running 6-7 pounds of boost, so it seems I was premature in my purchase. In other words, the intercooler is doing it's job well enough that the alcohol injection is not a noticable improvment. Eventually I will go with a smaller pulley and then it will be useful.
Originally Posted by LTNKLR01
what is it that you are actually injecting?? I wouldnt think that it is alcohol like you drink. What is it and where do you refill it. thanks
Originally Posted by BenKey
Put some Crown Royal in there, and it's in the 11s for sure.
Is that how all of you are so fast? Finally, the secret, I wont tell anyone though
smc kit is a well made kit. ive been running one on my grand national for about two years. able to run up around 18 psi on 93 octane, no probs. denatured alky with klotz lube to keep the pump lubed has been the ticket for me. Steve at smc is great to deal with.
lxcoupe
Jul 21, 2015 02:12 AM
