Alignment Pin for 3 bolt cam?
If you're referring the pin in the stock cam there really not, its not at all recommended as its press fit. Which is why I want to find one for a cam swap. Comp doesn't send a new one with cam purchase anymore I guess.
Really, after researching as to why this cam didn't come with one, I ran across several with the same problem, no pin. The only info I found was the ole vice grip and vice method to remove pin from stock cam. Which is dumb IMO.
mr03silverado
Jul 17, 2015 02:15 PM
