air intake tubes
Old Jul 2, 2005 | 11:46 PM
Coban's Avatar
Default air intake tubes
Now that I got the fan shroud out, I need a better looking tube. How is everyone liking the Airaid MIT? There's another one too that I can't think of. What other ones are yall using that have gotten good results from?
Old Jul 3, 2005 | 12:06 AM
NJAV's Avatar
I currently run the stock K&N black intake, but I think they have a series 77 or something like that which comes with a polished intake tube.
Dave
Old Jul 3, 2005 | 12:48 AM
BlackLM7's Avatar
I have the true flow intake system (www.trueflow.com). It's basically just a foam panel air filter and a steel tube going from the airbox to the throttle body. I didn't notice any power gains but it sure cleaned the engine compartment up. It's similar to the Airaid MIT design. Check it out.
Old Jul 3, 2005 | 01:00 AM
I am using a MAC perfomance CAI. The tube and heat sheild are both chrome. $199.99 for the kit. PM me for the url.
Old Jul 3, 2005 | 09:14 AM
unklej's Avatar
I used to have an airaid MIT but my 1/4 mile times showed little to no improvement. My gains (if any) ranged from 0-.01/.02 seconds. So I ended up selling it because it was a pain to get the airbox opened and it transferred more vibrations to the box/MAF. However, it did look nice, so if a clean look is what your going for...then, it's not bad.
Jeff
Old Jul 3, 2005 | 09:31 AM
one03sierra's Avatar
Formerly one92rs
Talking
you can go to http://shop.airflowonline.com/Merchant2/merchant.mv and build an intake tube for much less.
Old Jul 3, 2005 | 12:42 PM
smokeydoge's Avatar
Whatever system you use, make sure it does away with the factory rubber couplers- they create a full inner-diameter obstruction of about 1/4".
See my controversial intake shoot-out thread. Three intakes, same day, same dyno. aFe made some unreal numbers
Old Jul 3, 2005 | 12:54 PM
SSlow 4.8's Avatar
Airaid mit is actually made to fit with the shroud, its a pancake pipe like the stock one, just doesnt have the extra lower chamber (which is usless btw).
But something that is the same diamter throughout is best...
and like smokey said, afe is making some good numbers.
Corvette454l88
Sep 1, 2016 01:24 AM
AHelm3
Apr 8, 2016 07:51 AM
Ketis
Jul 23, 2015 12:37 PM
Suburban2500
Jul 14, 2015 02:10 AM
supersportsteve
Jul 4, 2015 12:02 PM
