aftermarket valve cover
Old Aug 13, 2018 | 05:35 PM
Tig's Avatar
Tig
Originally Posted by Go5.3tt06
i think your wrong size for drill 9/16??
The man gives you accurate info and you question him?
Old Aug 13, 2018 | 09:38 PM
Feed's Avatar
I'm just over here like drink, horse...DRINK!!
but seriously npt size call outs can be confusing to somebody that doesn't drill and tap holes for a living.
I'm assuming tapped section of valve cover is going to be relatively thin. 3/8 npt is 18 threads per inch. .055" pitch. If section thickness is 1/8" that's about 2.25 threads of engagement. Probably enough for what you want to do, but not ideal.
Old Aug 14, 2018 | 07:42 PM
Go5.3tt06's Avatar
Originally Posted by arthursc2
I love when you give the guy the info he needs because he didnt want to look it up, then he calls you wrong hahaha.
I wonder if he knows drills come in decimal, fractional, wire gauge, metric, left hand, single flute, center cutting/face cutting, 118°, 135°: etc. I mean the list is miles long, but lets not forget, he thinks youre wrong ahahaha
Sorry, **** cracks me up.
i know. I did google and I felt not trust myself if i get wrong size. That’s why I gave a chance comment here. I guess just order bung and once i have it. I will measure and find right drill bit and tap.
Old Aug 14, 2018 | 08:19 PM
arthursc2's Avatar
The science is already done for you man. Literally, a 100yrs+ of R&D are behind those charts you find on google. I have been a journeyman machinist nearing 12 years, that guy Feed obviously knows his stuff. Just hit it with a 9/16 bit. I myself would hit it undersize and ream it to .562 for a nice round hole, or weld in a bung. But, I like welding. Went to school for it. I weld everything. Liquid bolt.
But I digress, 9/16 and call it a day. Lube up the tap nice and wet, hold the valve cover securely (npt taps by hand are tricky) and make sure it goes in straight and square. Some oil resistant tape or dope, and let er ride.
bitterfitter
Aug 13, 2013 04:21 PM
Atomic
14
Mar 30, 2011 07:50 AM
marovetsm
Jun 19, 2010 07:08 PM
