aftermarket or stock ecm??? wtd
Old Nov 26, 2004 | 05:04 PM
sleepybu's Avatar
Question aftermarket or stock ecm??? wtd
i'm thinking about swapping in a 5.7 or 6L into my malibu but i don't know weather to use the stock ecm or go aftermarket. I do intend in tend to add boost rite away and thats why i'm looking for your opinons
If an aftermarket system which do you guys sujust
thanks
Old Nov 26, 2004 | 05:18 PM
one03sierra's Avatar
Formerly one92rs
Talking
well i think that the stock pcm will handle most of the power you are going to wsant to push. but i think there is an aftermarket one that parish is using. megasquirt i think. pm him or maybe he will chime in.
Old Nov 30, 2004 | 10:42 AM
dieselgeek's Avatar
Just saw this post... Jim's got the first LS1 Megasquirt up and running, controlling Fuel, Fans, and Nitrous. I built the MS, he installed it. It works great.
It does the same thing a Big Stuff 3, FAST, or DFI Gen 7 will do for you. (Actually, it does more than some of these). BUt like with any other standalone, you must be prepared to make a technical commitment - there are always bugs/issues you'll face when both learning the ins & outs of standalone ECMs, and learning the tuning process in general (two separate learning curves you face at once).
However, Megasquirt price makes it the best bang for the buck - bar NOTHING.
I think that you should only consider a standalone EMS when you KNOW your current engine management won't comfortably support the mods / power levels you seek... However, I've seen some guys approach it differently - they get the motor running on the standalone in a near-stock (easy to tune) configuration, and get comfortable with tuning, THEN they do the big mods. It depends on what will work best for you.... the one thing I can GUARANTEE, is if you set up some kind of deadline before installing an EMS, then sure enough you will blow that deadline. I.e., don't schedule the dyno pulls before you have the bugs worked out.
-scott
Old Dec 4, 2004 | 08:50 PM
sleepybu's Avatar
thanks guys
mzoomora
Jan 3, 2016 07:06 AM
JordanH
Aug 8, 2015 07:59 PM
ou812sm
Jul 28, 2015 08:24 AM
bk_cauley
Jul 8, 2015 05:37 PM
Nimoryan
Jul 5, 2015 03:50 PM
