Aftermarket Crank Pully? who makes them
Old Dec 24, 2004 | 10:18 AM
NORCAL STI's Avatar
Default Aftermarket Crank Pully? who makes them
all the cars/trucks ive had ive used a aftermarket crank pulley. in every case i felt a difference in power. Now who makes ones for the 5.3 2004 trucks and where can i get it and how much are they?
tony
Old Dec 25, 2004 | 12:58 PM
hellbents10's Avatar
LS1Tech Sponsor
Money might be better spent elsewhere as they sometimes cause KR issues.
Old Dec 25, 2004 | 01:12 PM
FILE's Avatar
Give ASP pullies a try.
Old Dec 25, 2004 | 01:30 PM
abbo7's Avatar
I have the ASP pulley, its kinda a pita to install and pricey. It is a very well made piece however. I have no problems with mine, and it is suppose to give you ~12 rwhp. I think that there are other mods you can do that are probably better, but I'm happy with it.
I also vote you replace your clutch fan with some lt1 or ls1 e-fans if you install a crank pulley, it would be the perfect time to do so. You will notice power with the e-fans and pulley.
Old Dec 25, 2004 | 02:16 PM
I was told the ASP puley will give 10 to 12rwhp. And installing e-fans is soposed to give another 10 to 12rwhp also.
Old Dec 25, 2004 | 09:43 PM
ktmrider's Avatar
Agreed, ASP is your best bet. I also think they make a woodruff key version if you go supercharged later on to avoid pulley slip.
black00chev
Aug 12, 2015 01:56 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
lxcoupe
Jul 21, 2015 02:12 AM
bk_cauley
Jul 8, 2015 05:37 PM
GreyChevy
Jul 7, 2015 08:57 PM
