Aftermarket cam for 5.3
Old Mar 11, 2002 | 10:20 PM
Closer_2001's Avatar
Default Re: Aftermarket cam for 5.3
Has anyone swapped to the 6.0 L Truck/01 Vette Cam in their 5.3?
You could probably pick one up for less than $100 from a Vette guy.
198/204
.500/.500
116 LSA
Might not sound manly, but it might generate the torque the heavier trucks need. C5 Vettes put out over 300 ft lbs at 2000 RPM.
Old Mar 12, 2002 | 01:55 AM
shyster7's Avatar
if i add a ls6 cam to my 5.3, will it require some computer work. I have a hypertech reprogramer, but do i need something to change the fuel curve or other variables?
Old Mar 12, 2002 | 08:40 AM
Nine Ball's Avatar
LS1Tech Co-Founder
you may be able to get away with a MAF-Translator to adjust the rich/lean properties. Its about $180.
We run almost all of the cams in our F-body motors and use stock fuel/timing tuning. These LS1s seem to be pretty forgiving in that regard. Most of the custom tuning done to our PCMs are involved with drivability issues.
-raising idle rpm (neutral and in drive)
-raising shift points
-raising rpm limiter
-adjusting MAP sensor on bigger cams
-removing some common SES codes
-making our fans come on earlier (not applicable on trucks)
-deletion of rear O2 sensors (no need for sims)
Just some examples.
Tony
Old Mar 12, 2002 | 11:18 PM
shyster7's Avatar
Ive got two more questions for your guys. Should i buy new lifters when i do the cam swap? And what is a maf transfer?
Old Mar 13, 2002 | 10:37 AM
norcal5.3's Avatar
slp also makes a cam kit but it is kind of pricy... about 500 for the complete kit...
I took a rock to the windshield on the way to work this morning... anyone had to replace the windshield on their truck??? what kind of money am I looking at??
Old Mar 13, 2002 | 07:06 PM
JUSTINB's Avatar
will the gm hot cam work in our trucks
<small>[ March 13, 2002, 07:33 PM: Message edited by: JUSTINB ]</small>
elpyro89
Jul 28, 2015 05:51 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
bk_cauley
Jul 8, 2015 05:37 PM
