AEM to EGR
Old Dec 6, 2010 | 06:39 PM
Default AEM to EGR
I tried searching but I think the phrases are too small. I'm wondering what wires goto where. I have removed the egr so I figured that I could use that wiring harness instead of using the a/c which I use.
Old Dec 6, 2010 | 09:05 PM
KLUG'S SS's Avatar
FormerVendor
You will want to use the brown wire at the EGR harness which is the EGR pintle position reference wire running to the PCM which if I remember correctly is pin 55 on the blue PCM connector. This is the 0-5 volt reference that you will need and then you will need to log PID 2811 in the main table which is EGR Position (Volts) and then of course setting up the histograms, etc..... which is pretty easy
Old Dec 6, 2010 | 10:00 PM
I remember reading something quickly on hptuners about that but thought that was going through the pcm and didn't realize it was utalizing the egr. Thanks for the clarity.
Pimpinpete
43
Dec 22, 2017 08:13 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
Velocity1
Oct 12, 2015 10:39 PM
Pimpinpete
Sep 8, 2015 07:39 PM
