advice on an old school truck
Old Feb 23, 2007 | 07:59 PM
  #31
CHEVRACER83's Avatar
A Meaty Small Block... 383 With The Right Heads... A Good Midrange Intake And A 850-950 Demon Will Get You Close.... But Everythings Gotta Be Matched Up...
And If Your Planning On Running 12's You Better Have Some Good Gearing... Id Say 4.10 Or 4.56 A Solid Tranny With A Heavy Shift Kit In It. A Decent Stall And Some Luck... And He Could Be Deep Into 12's
Thats Pending Of Course He Doesnt Melt The Hides Off The Line
Old Feb 23, 2007 | 09:05 PM
  #32
YenkoST's Avatar
Originally Posted by Frito Bandito
Good info, but I disagree about the pistons. Myself and a few people I know have had great success with KB hyperutectic pistons. Mine were in an NA engine, but friends have run them in 525hp NA engines and nitrous engines with up to a 150 shot. I don't know about any other hypers, but KBs kick *** and I would buy them over TRWs any day of the week. If you are going forged my opinion is to spend a little more and get SRP, JE, Wiseco, etc... Check out the LT1 guys over on camaroz28.com running KBs in 500+HP 383s.
Vortec heads are certainly something to consider. I haven't been too interested in them since aluminum heads are pretty reasonable. I didn't even think of the ignition but an HEI is definitely the way to go and you can't go wrong with MSD.
Anywho, lots of information here for Dry_Kill's friend to consider.
I have hypers in my current 383 and my engines from now on will have forged. Its worth the money to go forged on that part IMO.
Old Feb 23, 2007 | 09:11 PM
  #33
YenkoST's Avatar
Originally Posted by 67Style
There is some good info and some bad info in this thread. He will not need a BBC or any type of boost or nitrous. Go with a 383. Do not buy hyper. pistons. Best bang for the buck would be a set of forged TRWs. Shoot for around a 11:1 cr. A SCAT cast steel crank ($269~) is a good part. It's what I'm running for now as a matter of fact. Next, I would look at the vortec top-end kits from SDPC.com. Go with a 1-inch carb spacer and an 850 dp holley. Atleast a good HEI distributor, I run all MSD parts. Then a set of cheap 1 5/8 headers will do just fine.
For the tranny get a 3000-4000 verter, get the th350 rebuilt that is already in it, and you will need a tranny cooler! Out back that 10-bolt will last for now. So I'd just install a full spool (does fine on the street) with a set of 4.10s and a 28" tall ET street.
You'll be at 12.80s trapping about 103-106. Good luck!
Here is link to a site for my truck...67 Chevy
Very good info here. However, IMO, with a daily driver truck, I would perfer a 10:1 so you can run 89 octane with less timing and a 750 carb instead of a 850.
Old Feb 23, 2007 | 09:58 PM
  #34
Its possible like Bluecajun said 383 stroker small block Aluminum heads port/polished + CompCams Magnum Cam or custom grind + Victor Jr intake + Holley double pumper + fully bolt-on.
As for the transmission Built THM-350 or 400 with 2800-3000 stall or 700R4/4L60 with 3400 stall and for gearing 3.73/3.90/4.10s
Old Feb 25, 2007 | 05:51 PM
  #35
67Style's Avatar
He shouldn't need to p&p the heads. I'm running AFR 190s out of the box and they do great. I also really like the Edelbrock 200 E-tec heads (aluminum vortecs). They are cheaper than the AFRs too. I think the RPM Air-gap intake would be the better choice on a truck. The torque curve is lower...
Old Feb 25, 2007 | 08:50 PM
  #36
ls1_cam2's Avatar
Hey guys kind of new to the site, I am dry_kills friend. All this info is very helpful and it seems that I am going to go with the 383 and really good matching parts. Any good companies/people that I should speak with on making sure that all parts match bc I know for a fact that if the parts dont all work together it will a be a waste of $$$.
Old Feb 26, 2007 | 06:48 AM
  #37
chevydad's Avatar
12's should be easy.
i have a 83 chevy, i'm at 13.5 with it now and i would say it's very mild. it's a 2wd shortbed. with half tank of gas it only weighs 3750lbs. i have a 91 350 block out of a caprice police car, i added vortec heads and a performer rpm intake. i used a stock lt1 roller cam out of a 94 transam. that's it for the motor. the tranny is a th350 with a tci 3500 stall convertor. the truck runs 3.42 gears and 28" tall tire.
i would say if i did roller rockers and a nice sized cam i could probably touch 12's. i'll never know though, i'm selling the motor and dropping in a gen3 motor
Old Feb 26, 2007 | 08:02 AM
  #38
67Style's Avatar
If this kit from Edelbrock was around when I started my engine build, I may have bought it. It should work very well with a good tranny, stall, gears and tire.
Edelbrock Top-End Kit
Old Feb 13, 2008 | 05:37 PM
  #39
BadAssChevy327's Avatar
im running a 355 with 11.1 world product sportmens 2 (200cc intake , 2.02,1.60) all forged , solid roller 555 lift with 1.5 rockers and a tru 248 dur at 110. vic jr , demon 750 mec, 3,000 stall , th350 , 3.90 with a 28 inch tall et street radial . yet to have it at the track due to problems here and there and now redoin fuel system . but this ridesssssss . there much much more but im in positive in a mid 12 on motor if not better . also fixing to do 1.6 rockers , and port match the vic jr and port the incoming side of it a bit . and a dual stage nitrous kit . ive ran some locals around town on a dig and rolls thats what im basing my guess off of time on . but i should have it at the track come mid march gettin ready for pinks all out .
Old Feb 13, 2008 | 07:58 PM
  #40
Dock Rocker's Avatar
Holy bring a thread back from the dead batman!
