advice on an old school truck
Old Feb 21, 2007 | 08:42 AM
Dock Rocker's Avatar
Those trucks are heavy and have a very poor aero design. You can get into the 12's easy with a good strong motor and about 150 of spray. I just built a 383 with a carb that dyno'ed in at 390 horse 440 TQ and that is with stock vortech heads. If you take your time match up your parts you can make it fast but you are fighting an up hill battle make sure that you do as much weight reduction as you can.
Old Feb 21, 2007 | 09:55 AM
02sierraz71_5.3's Avatar
Reading a book by vizard on the very subject.
Tell him to go to barnes and nobles and get it
Old Feb 21, 2007 | 12:52 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
I agree with the "brick" design, but as far as weight... My RCSB C10 weighs in at 4260 with me in it. I weigh 215lbs, plus I had a 50lbs (thick) bed matt in the bed of the truck, spare tire, two full tanks of gas (16 gal tanks), and no weight reductions. From what I'm told by NBS RCSB owners, my truck is lighter. I honestly think mid to high 12s is realistic with the right mods, and "common" weight reduction (including my slightly overweight self ).
Old Feb 21, 2007 | 01:03 PM
Tig's Avatar
Tig
572 crate motor with some sick FI system would get him there.
Old Feb 21, 2007 | 02:20 PM
txredxj's Avatar
with those trucks a 4 link is a must or a 3 link
Old Feb 21, 2007 | 05:08 PM
Frito Bandito's Avatar
I'm pretty sure those trucks are lighter than the 99-06 models, so it should be easier to make fast than our trucks. Anyway, I would use the 350 block to build a 383. Shoot for 9.5:1 - 10:1 compression, get a decent set of heads with moderate sized intake runners like Canfield 195s/AFR 195s/Trick Flows, a roller cam (call his cam company of choice and have them grind something for his application), top it with a performer RPM intake and a mechanical secondary 750CFM carb and throw in some 1.75" headers. Back it with a built TH350 or 700R4 with at least a 2800 stall and some 4.10s. Throw in some sticky tires and I bet he runs 12s.
Old Feb 21, 2007 | 06:23 PM
TarheelZ's Avatar
Good call...that sounds like the recipe for some serious fun!
Old Feb 22, 2007 | 12:55 AM
dinnut's Avatar
i know a little about the subject i just put a 383 in my 70 longbed chevy. havent gotten it to run yet but hopefully itllmove. i went .060 over hypereutectic pistons. bout 10:1 whole new bottom end. dart heads 2.02/1.60 with a 200cc intake runner. 64 cc combustion chamber. lunati voodoo cam 219/227 .468/.489 112lsa. performer rpm with edelbrock 600 (probably gonna be too small). hasnt been fired yet still waiting to purchase new headers to fit the angle plug heads. oh yeah i put a new accell hei, super coil, tr55 plugs, and accell wires. stock th350 with a 2500 stall and a shift kit. curretly 3.08 gears gonna switch up to 4.11s with some sticky tires hopefully ill be ableto push it low 13s.
naturally aspirated makes your situation a little more difficult. check out the kits sold through summit and jegs to punch a stock 350 up to 400 horses or so and choose a little better parts than that
Old Feb 22, 2007 | 01:25 AM
YenkoST's Avatar
383 is the way to go for a deep 12 NA pass. You can do it with a 350 but you will need a more serious cam and heads than a 383.
Old Feb 22, 2007 | 04:21 PM
dry_kill's Avatar
ya i think this idea sounds best, ima run it by him and see what he says. Any idea how much money would be involved by going this route?
