advice on changing oil pump?
Well my oil pressure has been reading low and get a tapping noise so i quit driving the truck. Went to back it out of garage so I could clean the garage and oil pressure dropped to zero and low oil pressure light came on. Oil level is fine, just changed oil 2000 miles ago. I have been trying to find write ups on changing out oil pump and most of what I see talks about changing out an o-ring on the pick up tube by dropping the front two bolt on the oil pan and says to use a red ring, but I want to change out the whole pump. Can I do everything by dropping the oil pan from the bottom or do I gotta work from the front of the motor too? Any advice out there before I tear this thing apart and ruin it
got to do both. must access the front to get pump off. need to lower pan to get to the pickup bolt. its a pain in the ***. tip i learned while putting the pickup tube back on, factory only has one bolt on the tube and it didn't want to go in straight. i put a second bolt w/ a large washer in the other hole and slowly tightend both bolts. get an extra o ring in case you pinch the first one. you can tell if it goes in right. you don't want to put it all back together and have to start over. i got a used pump w 50,000 miles on it if you want it. sell it cheap, holds good pressure. if you go new slp has a nice piece. good luck.
Thank you, that's kinda what I figured, will keep this in mind.
It's easy to change the oil pump and drop the pan, you have a 2WD right? 4WD trucks are a BEAR to drop the pan on.
I recommend going back with 2 o-rings on the pickup tube to ensure a good seal. The OE ring is a "block" ring and is slightly taller than most circular o-rings. I've had very good (reliable) results using dual rings.
Replacing the oil pump is spec'd out to be a 5.2 hour job, but since you don't have to finagle the oil pump back on over the pickup tube it's pretty quick.
Since you're in there already I recommend replacing the timing chain with a new OE set. Cheap insurance against future problems.
I put a new LS2 chain in it 55,000 miles ago when i had the 6.0 swap done and the motor, heads, and springs and stuff have about 85,000 on them...I have been contemplating on pulling the whole motor myself and puting on a set of new ported LQ9 heads complete with new springs, lifters, rockers, cam etc. just for fun and a learning experience, part of me has always wanted to do something like that. Im half decent with a wrench but no mechanic by far, I have done brakes, rotors, starters, alternators, fuel pump, and stuff like that but nothing that extensive.
Ferocity02
Jul 17, 2015 07:05 PM
