advance in LS6 cam?
Old Jul 25, 2010 | 10:46 PM
2001CamaroGuy's Avatar
Default advance in LS6 cam?
Simple question:
Is there any advance ground into the 02 LS6 cam?
I found this on the CTS board:
02+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
02+ LS6 cam - 0.006" | 0.050" | 0.200 "
Intake Duration ID - 270 | 204 | 166.6
Exhaust Duration ED - 275 | 218 | 178
Lobe Center Angle LSA - 117 | 117 | 117
Intake Centerline ICL - 117.4 | 118.9 | 118
Intake Valve opens IVO - 17.6 | -16.9 | -34.7 BTDC
Intake Valve closes IVC - 72.4 | 40.9 | 21.3 ABDC
Exhaust Valve Opens EVO - 74.1 | 44.1 | 25 BBDC
Exhaust Valve Closes EVC - 20.9 | -6.1 | -27 ATDC
Exhaust Centerline ECL - 116.6 | 115.1 | 116
Overlap 38.5 | -23 | -61.7 degrees
That seems to point to the cam having about 1 degree of retard in it.
More difficult question:
To advance or install dot-to-dot?
I found this:
Originally Posted by Patrick G
The School of Automotive Machinists (SAM) has done extensive engine dyno testing on LS1s and has come to the following conclusion. Intake closing point is the most important determining factor for where (and how much) power the LS1 makes.
Cams that have an intake closing point of 40 degrees ABDC tend to make peak power around 6000 rpms. Close the intake around 42 degrees, they peak around 6100. 44 degrees, 6200 rpm power peak. 46 degrees, 6300 rpm power peak.
You can vary intake closing point by playing around with duration, LSA and ICL. For example:
TR 224/224 112LSA +4 cam has intake closing point of 40 degrees ABDC (6000 rpm peak).
TR 224/224 114LSA +4 cam has intake closing point of 42 degrees ABDC (6100 rpm peak)
TR 220/220 114LSA +0 cam has intake closing point of 44 degrees ABDC (6200 rpm peak)
2002 ZO6 204/218 117.5LSA -2.5 cam has intake closing point of 42 degrees ABDC (6100 rpm peak)
TR 230/224 111 LSA +2 cam has intake closing point of 44 degrees (6200 rpm peak)
MTI 209/216 116LSA +4 A1 cam has intake closing point of 36.5 degrees ABDC (5600 rpm peak)
I'm going to be installing it in my 5.3 silverado and I'm trying to decide if I'd like to try setting it off dot-to-dot (I have a double roller adjustable timing set with up to +/- 8 degrees).
Obviously a 5.3 is going to want to spin a higher than a 5.7 on the same cam. All the dyno graphs I have seen of stock LS6s seem to put the peak torque at about 4700RPM and peak horsepower at about 5700RPM. Thus with the 5.3, dot-to-dot I'd think about 6000-6100RPM horsepower peak.
With all this in mind, I'm thinking I might advance it +2 degrees to bring the peaks back down a bit, but I'm not sure. Everyone I know of just runs it straight up (though this could be for simplicity and not having an adjustable timing set).
Thoughts?
ARC
57
Feb 21, 2022 10:54 AM
darnie
Aug 10, 2015 10:25 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
Aboss
Jul 9, 2015 10:28 AM
