Adding Fuel Pressure Regulator - Swapped TB's
Old Jun 16, 2007 | 08:37 AM
agreif's Avatar
Default Adding Fuel Pressure Regulator - Swapped TB's
Guys, I swapped the drivers side fuel rails and my only question I have now is, how do I pull the nipple out of the old intake to get the fuel pressure regulator line hooked up to the intake?
Let me know what you think?
07 intake
01 intake
Old Jun 16, 2007 | 08:51 AM
BigTex's Avatar
Look on the other side of the intake for an extra place to pull manifold vacuum. Many of the other truck intakes have an extra hose barb on the opposite side with a little plastic strip over the top of it. Just cut back the strip to open the barb and hook up a longer hose to that location. If you can't find that spot on your intake, put a "T" into the PCV hose that goes right next to it to the top of the manuifold. Both will give you the vacuum pressure that you need.
Old Jun 16, 2007 | 09:26 AM
litreddevil's Avatar
Banned
what big tex said
are you can just put the other intake on that has the port
Old Jun 16, 2007 | 11:24 AM
agreif's Avatar
duh, I saw that after I posted and went out and looked again. Sorry guys and thanks for helping out the rookie.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
