Adding Fuel Pressure Regulator - Swapped TB's
Guys, I swapped the drivers side fuel rails and my only question I have now is, how do I pull the nipple out of the old intake to get the fuel pressure regulator line hooked up to the intake?
Let me know what you think?
07 intake
01 intake
07 intake
01 intake
Look on the other side of the intake for an extra place to pull manifold vacuum. Many of the other truck intakes have an extra hose barb on the opposite side with a little plastic strip over the top of it. Just cut back the strip to open the barb and hook up a longer hose to that location. If you can't find that spot on your intake, put a "T" into the PCV hose that goes right next to it to the top of the manuifold. Both will give you the vacuum pressure that you need.
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
