AC belt will not stop squeaking.
#22
Baltimore Whore
Well if you would try that, give this a shot. Soak your arm in gas, light it, then fist **** a goat. Should do the trick. I never put my AC belt back on after install, '' because race truck'' Can you not pin point the noise? Sure it isn't the compressor some way or another
#27
So when i did the last round of engine mods, i swapped out the harmonic balancer because i broke the ear off my old one. Well i bought it used from a member on here. I am going to replace it, perhaps that is the issue, i dunno... If that does not fix it i will replace the AC compressor... I ordered a brand new balancer from rock auto so it should be here in a few days.
