ABS warning light??
Old Apr 6, 2004 | 06:56 PM
fullback40's Avatar
Default ABS warning light??
Ok yesterday after 43,000 miles the brakes on my HD 2500 started to sqeal. So while I was coming home from the Chevrolet dealer with my new brake pads my ABS warning light came on. Is this normal when you need a brake job or is there something else I should be checking ??
Old Apr 6, 2004 | 08:08 PM
fullback40's Avatar
I did a search and no good info came up anybody else have this happen to them ??
Old Apr 6, 2004 | 11:35 PM
Hit Man X's Avatar
Something's not right, I'd take it back over there if they did the work it should be under warranty.
Fluid could be low, a sensor smashed/broken, etc.
Old Apr 7, 2004 | 08:30 AM
lastSS's Avatar
I had my ABS warning light come and it was the ABS sensor in the right front wheel. I took it to the dealer and they fixed for me, under warranty. They only did it under warranty since they scratched my truck previously. I have a lifted truck and I drive off road sometimes. I hear this is common to people like me. I have bee watchint it more carefully now. Just look under your wheel weel, mine had come unattached from the suspension and was rubbing on the inside of my wheel.
Old Apr 8, 2004 | 03:35 PM
fullback40's Avatar
Found out it wasnt my brakes at all it was my hub. The bearings were wore out and the wheel was rubbing against my calibers and melted the ABS sensor. I replaced the hub which came with a new sensor and all is well my brakes were fine.
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 1, 2015 09:22 AM
Blklgt
Sep 28, 2015 03:21 PM
Lthompson
Sep 21, 2015 07:06 PM
