about to buy a 4.3 truck, whats the diff in swapping to 6.0 compared to...
Old Jun 27, 2005 | 07:20 PM
>X<'s Avatar
>X<
Default about to buy a 4.3 truck, whats the diff in swapping to 6.0 compared to...
whats the difference in the 6.0 swap if i start with a 4.3 truck. i searched for a minute but couldnt find anything, so sorry if its right in front of me. i am about to buy a 99-03 gm, and it would be real easy/cheap to settle for one with a 4.3, but i know i will end up doing the 6.0 swap soon, so is there any difference in the wiring/tranny/etc that will cause problems with the 6.0 swap? any 6.0 swap threads/sites that i should read? thanks, sean
Old Jun 27, 2005 | 07:56 PM
Leroy_454's Avatar
I would recommend finding a truck that already has a V8. Anything from a 4.8L up. There would be lots of wiring differences and many parts you would need. It is pretty much a direct swap with a 4.8, 5.3.
Old Jun 27, 2005 | 08:16 PM
mason110's Avatar
definatly start with a 4.8 atleast alot of diffrences from a 6 to a 8 cylinder
Old Jun 27, 2005 | 08:29 PM
>X<'s Avatar
>X<
i knew it was pretty much direct with an 8, just didnt know the details of a swap from a 6. thats all i needed to know, now 4.3 is out. thanks guys.
any good reading on the swap?
Old Jun 27, 2005 | 08:36 PM
Leroy_454's Avatar
There is some good reading, but unfortunately the search is not working yet.
Old Jun 27, 2005 | 08:38 PM
iLLuZioN's Avatar
i may be doing this in the near future also... in a 99-02... so everything else just bolts up with the 6.0 if i got a 4.8 and up? same wiring? what about the pcm?
Old Jun 27, 2005 | 08:47 PM
Leroy_454's Avatar
It is almost a direct swap. You use everything external off of your 4.8/5.3 (intake manifold, all sensors, etc.) You just need the long block. It is important to get a 6.0 from a year model 2001+ if you are installing this on a 4L60E. The 99-2000's have a slightly longer crankshaft and are designed with the 4L80E in mind. A stock 6.0 will more than likely run on a stock 4.8/5.3 pcm tune, but tuning for the larger engine is highly recommended.
Old Jun 27, 2005 | 09:01 PM
iLLuZioN's Avatar
but where the hell can we get the 2001 and up 6.0s? ive searched and found a couple on various sites, but they all had something missing... is there an easier way to do this?
Old Jun 27, 2005 | 09:40 PM
litreddevil's Avatar
Banned
well a friend of mine is just finishing up with a 4.3 to a 5.7 lsi swap.it is very costly to do. but not to hard.the truck would be down for a little while also.
Old Jun 27, 2005 | 10:43 PM
Leroy_454's Avatar
Check www.car-part.com for used, or www.sdpc2000.com for new gm crate motor.
Bumpers
Aug 4, 2024 09:44 PM
SLOPONY
20
Oct 18, 2016 06:05 AM
Suburban2500
Jul 19, 2015 04:50 PM
black6spdz
Jul 16, 2015 01:32 AM
davis28905
Jul 8, 2015 03:20 AM
